VPS issue fixed, but collision avoidance issues now
2642 24 2017-2-19
NomadRT
Flight distance : 1669012 ft
Is anyone else having issues where the Mavic repeatedly comes to a sudden halt with warning beeps notifying you of an obstacle and advising you to alter your flight (or something to that effect).
My VPS landing issues seem to have been fixed by the latest firmware.    I was beginning to get these collision avoidance messages (and halts) before, but I assumed it had to do with the VPS.   Now that the VPS issues are resolved I'm staring down the barrel of false collision avoidance behavior.
Anyone?   Is there a calibration or diagnostic I can run?
2017-2-19
DroneFlying
Flight distance : 10774613 ft
Yes, this happens to me. It most often -- but not always -- occurs in bright sunlight.
Not that I know of.
2017-2-19
NomadRT
DroneFlying Posted at 2017-2-19 17:24
Mine seemed to happen in bright sunlight and also at dusk in low light.  In other words it seemed agnostic as to when it happened.
Sheesh man.   Such a bummer after finally getting the VPS issue fixed.    I can turn the collision avoidance off and it flies perfectly (and also seems to fly faster without collision avoidance -- pushing 30mph).
2017-2-19
Jenee 2
Flight distance : 7852129 ft
Yes this happens to me on the new firmware. On the 0200 firmware I had no problems flying toward the sun or using the RTH toward the sun but with this new firmware it is hopeless. Cannot use RTH toward the sun and cannot fly normally toward the sun. I can fly toward the sun at a crawl without a problem. Seems to be the tilting action that triggers OA.
I doubt there is anything we can do as this started with the new firmware.
2017-2-19
DroneFlying
Jenee 2 Posted at 2017-2-19 21:54
I agree that it seems to be happening more often since the last firmware update, but I can't be sure since all the conditions that trigger it have never been entirely clear to me in the first place.
2017-2-20
NomadRT
Based on my testing this weekend, it doesn't appear that there are any conditions or direction that triggers it.    I flew while the sun was directly overhead of the Mavic, in front of it, behind it, etc.   It didn't matter the level of light either.    I fly around for a few seconds and it hits an invisible brick wall and stops while giving me the warning messages and beeps.   It was even spontaneously hitting these messages and behavior on it's way back from on RTH, which is disturbing because if I got into trouble and needed it to come back it would just continually hit an imaginary brick wall and stay in place rather than returning.
I'm pretty crushed about this.    I waited for what seemed an eternity to just GET the Mavic, then I've waited for a month and a half for a VPS fix, and now I *still* don't have a working Mavic.    This has been the worst purchase decision in as long as I can remember.
2017-2-20
dnorm
Flight distance : 481778 ft
Hi Nomad and Team,
I'll have a test of this today, I have just updated, and was just flying over a river in really bright sunlight and also at dusk and on Saturday and didn't notice this issue.  TBH i am not 100% certain i have collision avoidance engaged though...so with that said...
I CAN confirm that VPS issues are seemingly fixed after that latest 02/14 FW release and update.
how would one induce or reproduce this new collision avoidance issue?  would like to give it a test.
let me know, thanks!
dave
2017-2-20
NomadRT
dnorm Posted at 2017-2-20 09:14
Hi Nomad and Team,
I'm not sure following any steps to reproduce it will do so if you aren't having it.    Mine happens just when normal flying unfortunately, and also under autopilot.   In other words I think you'd know it already because it would be happening to you regularly.
2017-2-20
NomadRT
I did have one thought though --    I just realized I've been flying my aircraft with DJI GO instead of DJI Go 4.0.    Could this make a difference?
2017-2-20
Jdwyier
Hi Nomad and Team,
I believe you would have to be in normal flight mode (not sport mode) and have Obstacle Avoidance enabled in the App in order to see an potential problems with it.
2017-2-20
PimpDawg
Flight distance : 1204754 ft
Same here. 300 feet up, sun overhead, not flying into the sun and I got an obstacle warning. Really disappointed with this $1000 toy plagued with so many issues. The camera is awful and the gimbal seems too weak for the drone's performance.
2017-2-20
DroneFlying
NomadRT Posted at 2017-2-20 09:52
I doubt it; my Mavic flying is always done with DJI Go 4 and I'm seeing similar behavior. I'm seriously considering downgrading to the previous firmware level to see if that helps, because although I've always had problems with OA being incorrectly triggered it seems to have gotten worse recently.
2017-2-20
dnorm
OK  my report:
DJI Go 4 - ipad mini 2...at 250 feet up - tree tops at 150...no obstacles up there.
three separate instances of 'obstacle avoided revise route' on the 02/14 FW with my mavic just moments ago...was seeing the radar arcs going off as well and hearing the beeps...blue sky sunny day.  Most of the flight was uneventful but definitely seeing this obstacle avoidance issue now.
something definitely going on here...VPS fixed...this is new as far as i can tell - or perhaps has always been there?
DJI - should we start gathering logs?
dave
2017-2-20
iPurvis
Flight distance : 13750 ft
Respectfully, The hardware that controls the VPS also controls the obstacle avoidance.... I don't want to suggest anything here but the firmware, to me, seems like a sticking plaster for a problem that can only be resolved by an RMA. Flying the Mavic seems like a game of whack-a-mole
2017-2-20
DroneFlying
I downgraded back to v01.03.0200, flew two full batteries, and got no false positives in partly cloudy conditions (though not over water this time). It may just be a coincidence, but I think I'm going to stick with this firmware version for a while since nothing I care about is fixed in the latest one anyway.
2017-2-20
motard
Flight distance : 1156263 ft
Portugal
How do you calibrate VPS?
2017-2-20
iPurvis
motard Posted at 2017-2-20 16:19
Go to assistant 2 on your computer, plug the Mavic in, and hit the calibrate button
2017-2-20
dnorm
i took some video of the behavior closer to the ground.
Based on these tests direct sunlight into the stereo vision sensors on the front almost certainly seemings to be the cause of this  issue.
see video below, sun is from the left in the video here - watch what happens as i turn in to the sun - OA kicks in abruptly (i have more videos as well,, but this is the most exemplary of the issue):
2017-2-20
Jenee 2
Is there anyone getting the RTH and OA problem on the new firmware and they have calibrated their VPS.
I originally got my Mavic on the v01.03.0200 and just flew without ever having a problem, even into the sun. I never even knew of the problem until two things happened. First I put an ND filter on and immediately RTH and flying into the sun became impossible (on the 01.03.0200 firmware), took the filter off and all back to normal. Upgraded to 01.03.0400 and all the RTH and flying into the sun and even OA when not flying into the sun happened. But I have never calibrated the VPS.
2017-2-20
DennisMurry08
Flight distance : 5948264 ft
I have the ghost obstacle too...I posted about it awhile back...still have it.
2017-2-20
SashaSWISS
Flight distance : 1534478 ft
Switzerland
Hello Mavic's
VPS problem solved....FINALY
BUT front collision avoidance IS A HUGE NEW PROBLEM towards the SUN ONLY !!!!
PLEASE DJI FIX THIS!!!!!
2017-2-21
canadianairborn
Am I the only one that fly's with all of the sensors disabled? I'll give it a year until the firmware is somewhat stable and bug free before using the sensors or "intelligent flight modes" not worth the risk or hassle IMO.
2017-2-21
iPurvis
canadianairborn Posted at 2017-2-21 07:39
Shouldn't DJI then be selling the Mavic without sensors? for a lot less money? The whole point of it having these tools is as a pilot aid and part of its selling point. To have to use the mavic without these tools then seems counterintuitive and pointless to buy, People may as well have put up with lugging around the P3P
2017-2-21
fans90d4f438
Flight distance : 451335 ft
I too found out yesterday via limited testing that using a filter plus flying into bright sunlight seemed to exacerbate the false collision avoidance issues. Why the filter has anything to do with it? I dont know. And may have been coincidence. But in my experience, flying into bright sunlight is an issue with the collision avoidance. Im on most current firmware as well.Didnt seem to have this issue prior to recent upgrade
2017-2-21
dnorm
pretty sure the ND filters don't have anything to do with it, the video above i posted is with the stock camera and no filters.
this seems to be a newly introduced issue since the latest firmware - at least one of which i am now aware.
dave
2017-2-21
