Having trouble with x5s and 12mm olympus
1178 9 2017-2-19
Skyris
Flight distance : 333799 ft
Hey, just wondering if anyone else is having trouble calibrating the 12mm olypus with the X5S.I used the same lens on the inspire pro and could calibrate it fine.
I am trying to calibrate this with a high contrast object over 50m but it is still saying the object is to close.
I have the 15mm working fine but its a lot narrower field of view and need the 12mm
2017-2-19
DJI Natalia
Flight distance : 318 ft
Skyris, can you calibrate it successfully with the original lens?
Please post a screenshot here for the error message "Object is too close", thanks.
2017-2-20
JBInspire
Flight distance : 1863438 ft
I haven't been able to calibrate my Olympus 17mm lens - getting exactly the same message even when pointing at objects over 100m away. However, I have still been able to use it and get well focused shots...
2017-2-20
sharif0
Flight distance : 621312 ft
I have the 12mm Olympus and no issues calibrating the X5S.
2017-2-20
DJI相机部大帅哥
DJI R&D Squad
It's because of the feature of 12mm lens. The distance information got from different serial of 12mm lens is different. But we have improved this feature in the next firmware. Please wait for the next firmware.
2017-2-22
JohnnieYaz
Flight distance : 5137874 ft
Tip: The post by the administrator or moderators shield
2017-2-23
JohnnieYaz
Would you have a link to the biggest zoom lens that will now work for the X5S? would like to get to 100mm but know that's not happening. I would like to be able to optically zoom from the DJIGO4 app and do you know if that's possible? is it??
2017-2-23
fanse186c04e
Flight distance : 26170253 ft
I have it in the other way, i can not get the dpi 15mm lens calibrated and the Olympus 12mm is calibrating fine.
Vince
2017-2-23
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, what mobile device are you using?
2017-2-24
Skyris
Samsung tab s2, I used this with the inspire pro and the 12mm oly.. worked fine, Just taken the inspire 2 out again and the new app firmware is a bit better but now the manual infinity focus keeps resetting after each photograph..
2017-3-1
