Seb
Flight distance : 659003 ft
Poland
photoholic Posted at 2017-2-20 07:09
great thank you very much for this... so in the first one you stay on one point rotating drone and gimbal and in the second one you shoot from different point right?
First of all, enable 30° tilt gimbal extension and on-screen gridlines. Then, move gimbal up so horizon is on the level of lower horizontal gridline. Take a photo, and turn right by 1/3 of the screen width. Repeat this until you make one full turn. Then lower gimbal by 1/3 of image height and make another full turn. Again, move gimbal down by 1/3 etc. Finally you will take last photos with gimbal pointing down. This way you have covered all the panorama with enough overlap for seamless stitch.
When making shots manually you can manage flares and artifacts so you will have much less work in post. You can also take into account road traffic and other moving things, that causes ghosting. It will save your time when masking photos. Remember, some things are hard to correct in post, and this is why I make all my panoramas from hand, and carefully inspecting all the photos I make. Sometimes I make additional photos etc. Some things are hard or impossible to do when you land and return to your home. |
