dronist
You need to do an IMU calibration. Follow the steps below.
I use IOS with IPHONE 6S+, but NO am not promoting IOS over ANDROID. This out of the way:
With every drone I receive I do the following the first and only time until I get future notification form the app.
Take battery and props off, leave it outside in cold temperature for at least 1/2 hour have your remote on and ready and bring AC back in, put the battery in and start RC/AC/APP, DO NOT UPGRADE, run the IMU calibration. Need to follow the screen EXACTLY. Again if it got stuck it means it is waiting for the correct position of the AC.
After that do shut everything off, TURN everything back on in the same order as before and then do an AUTOMATIC Gimbal calibration.
After that do shut everything off, TURN everything back on in the same order and NOW do the upgrade if needed. Again, fast internet or fast data connection.
Where you take off make sure you don't any metal, elcetronic or megnatic interference, keys, etc.
Let us know... If it did NOT work than start a CASE with support.
