dnorm
Flight distance : 481778 ft
dronist Posted at 2017-2-20 12:55
Frist, try using a different device, Cable. Not worked, do a factory reset and start as you have just receied your unit, COLD IMU Calib, GIMBAL Calib and then update process. I use IPHONE6S+ or MINI4 and had NO PROBLEM... Let us know...
why would my ipad mini 2 work perfectly with the mavic and not with the p4pro, have tried two different apple lightning cables, have also tried an anker powerline cable (mfi certified). All result in the same issue?
even if my iphone 7plus worked, i would not want to fly with it, the p4pro needs a tablet sized screen, not phone IMO.
may try factory restart and rebuild firmware once back with high speed internet - i'll see what DJI says, this could also be a transmitter issue i suppose?
dave |
