DroneFlying
Flight distance : 10774613 ft
BuzzCut Posted at 2017-2-21 12:06
The entire outer ring is plastic, right? I'm sure that doesn't help. The plastic probably wants to flex when you're taking it on and off of the camera, but the glass doesn't. That's sucky.
Yes, and they definitely do feel more fragile than the aluminum-housed competitors (e.g., Tacos). Installing these is easy, but I find removing them a little tricky: you basically have to pull two of the tabs away from the gimbal simultaneously. And to also support / stabilize the gimbal while doing that means that you have no hands free and just have to let it fall off. On the other hand, both installation and removal seem less stressful for the gimbal than the competitors' products. |
