ricci2
Flight distance : 61158 ft
Hi,
I think there is another small problem you might have to research and that is static, any rapidly moving conductive part such as Carbon will build up a charge and so as you might of seen with a vandergraph generator can be at a high voltage with the ability to jump to an object of lower potential. The battery chemistry is quite volatile even in an inert environment so lots of explosion proof housings would be needed.
The place to start is the facility safety rules and specs, that will let you know how they rate ignition potentials, could be the parts per million of inflatable material is so low due to very precise monitoring they will allow brushless motors. They use drones on oil rigs so their must be some exceptions.
ricci |
