Donnie Stugots
Flight distance : 3636782 ft
If you are big time serious , I would get two apple Pro's or airs, they work perfect , return the I pad Minis, I see this all the time . I just helped fix this exact same issue and here is what the member said below in bold . The problem is the GO app sucks a ton of power and the more and more complicated these sytems get with encryption , the harder the processors need to work .
Below was the same issue with signal problem on the salve remote.
( I guess you could get two high end androids as well, but the DJI is optimized for the apple systems , trust me I have talked to DJI reps on this, and have seen test on You- tube by independents, the high end I pads always have the least amount of siganl lag or issues )
****Yes I am an apple guy for the I pad and go app, HIgh end I pads work Perfectly ( I hate the MAC for loading firmware and formatting SD card , does not wipe it clean ) , and not bashing android or the I pad Minis, just saying in 9 out of 10 cases where there was in issue with the video and the Mini was upgraded the problem went away .
We have now undertaken some test with an iPad min2 and a iPad air 2.
Since upgrading from 1.8 to 1.9 and then 1.10 we where always losing live video feed so over the weekend we replaced our iPad mini 2s with iPad air (same price or maybe a little more as a iPad mini 4 )
(bit faster and a bigger screen) we now have a good feed on both controllers,mode.
This above is post #24 from this thread below , some editing but did not change the message
http://forum.dji.com/thread-80987-1-1.html
You friendly neighborhood .....donnie man
