Aardvark
Flight distance : 384432 ft
Geebax Posted at 2017-2-27 00:48
Just for everyone's information, the signal fed to the viewing devices is MPEG, and by its very nature, the stream takes time to decode, because certain items are not defined until several frames after they are shot. I have 3 television sets in close proximity, and it is not unusual for one or more to be lagging behind another. Switch one off and then one again and it can end up in front instead of behind. Changing firmware on the aircraft is unlikely to affect this issue, the main culprit is the display device. Try Googling 'mpeg decoder delay' and you will see what I mean.
I have a suspicion that there is an incompatibility between RC V1.8 and the HDMI module (And perhaps many Android devices), there seem to have been many cases where a rollback to V1.6 has at least reduced if not resolved display issues (Primarily Android). An extract from the release notes (aircraft firmware 1.1.310 last April) indicates an 'enhancement' to encryption between aircraft and RC to improve 'security', this was April last year. I read this as them having introduced encryption, or changed the encryption method. This also required the RC to be updated to allow both to communicate, I am trying to remember which RC version, I think it may have been V1.58. My thinking is that this 'enhanced' encryption places greater demands on the display devices.
The release note for RC V1.8 (Introduced October last year) suggests only two changes, one for the earlier GL300A RC when recording 2.7k video. And another to 'enhance RC to mobile device connection', and that is the bit that I think may be causing problems, this is my personal opinion only and I could be wrong. But it seems too coincidental.
