*Introducing new Takyon ESCs - Z660 and Z650*
5268 5 2017-2-23
DJI Joe
The DJI Takyon Z660 is designed for industrial drones. A custom designed System on Chip (SOC) and a modular design combine with efficient and intelligent motor control algorithms to make the DJI Takyon series ESC an extraordinarily fast and ultra-accurate motor control system. Takyon Z660 supports 3-6S battery with a maximum working current of 60 A. Featuring dust and waterproofing, the Z660 can provide reliable speed control solutions for drone applications including mapping, inspection, agriculture, security and other industries.
Widespread Applications
Takyon Z660 is compatible and reliable and is able to work stably under harsh environmental conditions. It can be used on drones for a wide range of industry applications including mapping, inspection, agriculture and security.
  • Construction
  • Smarter Farming
  • Power line Inspection
  • Aerial Photogrammetry
  • Security Inspection
  • Disaster Assistance
Remarkable Reliability
A sealed case makes the IP67-rated Takyon Z660 dust and water resistant, ensuring steady operation even in extreme conditions. It meets the demands of professionals working in security, inspection and other industries. The high-grade anti-static design, anti-radiation and anti-jamming protection, ensures Takyon Z660’s stable and reliable performance.
  • IP67 Rated
  • Nano Coating Technology
  • ESD protection
Motor Stalled Protection
Integrated locked-rotor protection prevents damage to motors in the event of a locked or blocked rotor. Takyon series ESCs constantly scan connected motors in real-time and will cut power if motors stall in order to protect the propulsion system from avoidable damage.
Power Recyclable
The power recyclable function provides longer flight times and higher flexibility. Takyon Z660 will slow down the motor and recycle power when receiving deceleration commands, providing excellent dynamic response and increased energy efficiency.
  • Active Braking Enabled
  • Active Braking Disabled
More Features
Excellent Integration
A custom designed 32-bit DJI motor drive SOC working at frequencies of up to 100MHz integrates a power management system, main control and driving system, making Takyon series ESCs smaller in size but with higher performance. Takyon Z660 can support PWM of up to 48KHz. It comes with a crystal oscillator for accurate control and quick responses without the need for additional throttle range tuning.
High Compatibility
Takyon series ESCs can be used on a wide range of square wave drive brushless motors including High KV motors without manual tuning through FOC Technology and self-adaptive control technologies. Takyon series ESCs support high-speed throttle signals at frequencies up to 500Hz and OneShot125 for fast throttle responses.
DJI Assistant 2
The included DJI Assistant 2 simplifies the processes of customizing how an aircraft flies. Set acceleration, timing, active braking, and throttle range according to specific requirements, or tune your aircraft for racing quickly and easily. DJI Assistant 2 can also be used for firmware updates, which bring a host of new features and upgraded compatibility.
* Takyon ESC Updater required for parameter settings and firmware updates
The small and powerful DJI Takyon Z650 was made for racing. A custom designed System on Chip (SOC) and a modular design combine with efficient and intelligent motor control algorithms to make the Takyon Z650 an extraordinarily fast and ultra-accurate motor control system. The Z650 supports 3-6S batteries with a maximum working current of 50 A, ensuring powerful propulsion.
Small yet Powerful
Just 1/4 the size of other ESCs with the same working current, the Z650 is perfect for a compact aircraft. The integration of high-performance components, new internal circuitry and optimized heat dissipation, gives the Takyon Z650 a smaller size, higher performance and better reliability.
  • Nano Plating Technology
  • ESD protection 35.8*19.6*9.4 mm size
  • 10 g weight
Efficient Heat Dissipation
Advanced heat dissipation technologies developed for the Takyon Z650 allow for higher performance even with a compact body where heat-generating components sit close. The Z650 uses low impedance components and replaces the Standard PQFN Package with the Dual CoolTM Package, increasing the thermal conductivity to the outer shell up to 10 times. The aluminium alloy shell further enhances the heat dissipation to allow for high powered aircraft to operate steadily for up to a whole day.
  • Multiple Heat Dissipation Design
  • 10 Times Thermal Conductivity
High Efficiency
Takyon Z650 thoroughly optimizes the effort-efficiency, increasing the power efficiency by 44%-59% and enabling longer flight time.
3D Mode
3D Mode affords Takyon Z650 instantaneous motor direction changes, enabling complex maneuvers that would otherwise be impossible.
Integrated locked-rotor protection prevents damage to motors in the event of a locked or blocked rotor. Takyon series ESCs constantly scan connected motors in real-time and will cut power if motors stall due to a locked rotor, protecting the propulsion system from avoidable damage.
Power Recyclable
The power recyclable function provides longer flight times and higher flexibility. Takyon Z650 will slow down the motor and recycle power when receiving deceleration commands, providing excellent dynamic response and increased energy efficiency.
Highly Compatible
A custom designed 32-bit DJI motor drive SOC integrates a power management system, main control and driving system, giving Takyon series ESCs smaller dimensions but higher performance. The Z650 can support PWM of up to 48KHz and comes with a crystal oscillator for accurate control and quick responses without additional throttle range tuning.
DJI Assistant 2
The included DJI Assistant 2 simplifies the process of customizing how an aircraft flies. Set acceleration, timing, active braking, and throttle range according to each situation, or tune an aircraft for racing, quickly and easily. DJI Assistant 2 can also be used for firmware updates, which bring new features and upgraded compatibility.
*Takyon ESC Updater is required for parameter settings and firmware updates.
2017-2-23
SkyMemories
Flight distance : 139967 ft
Malaysia
wow. nice job DJi. it looks awesome.. Hoping to see the video of the drone soon..
2017-2-23
fans21d78334
Excellent job,  this is the best option for professional development and industrial implementation.
2017-3-4
Mikkovtun
Flight distance : 5247953 ft
Ukraine
Нарешті можна літати в дощ та в пилу - захист ІР67 це чудово!
2017-3-5
Matthias80
Flight distance : 2601499 ft
When and where to buy? :-)
2017-3-8
Matthias80
3 months later...any news on this?!
2017-6-6
