fansa954d030
Flight distance : 167648 ft
RicardoGray Posted at 2017-2-23 12:53
I had trouble with V7 nougat too on my shield. It was not working as it had with both Litchi and DJI Go app. I ended up rolling it back to V6.0 and all is good again. I was hesitant because, I had just bought my new Shield and it asked for the update right out of the gate, and so I did it. I say this because I had been using an older Shield for over a year, and I gave it to my son who also has a P3A. It always worked perfect for me. Anyway, reluctant that I would maybe void my warranty, I put the previous version on it. I actually thought I could do a factory reset and tried it, but it came back up a V7.0, so the update over-wrote the original image file that it came with. It is not hard to do, and if you have never done it, there are many vidoes on how to. Just make sure you follow the steps to the tee, and make sure you get the right image file off of the Nvidia Developer's Download site. Then make sure you turn off "Automatic Updates" so it doesn't prompt you again. Good luck. I really think going back to either V5.0 or 6.0 android will fix your problems.
Hi richardo,is there any chance you could point me in the direction of the guide you used for downgrading as im also having big problems with nougat on both apps?
Thanks very much |
