How lose should my gimbal be?
965 8 2017-2-23
Youbdun12
I recently had to catch my Mavic mid flight because I did not want it to fall in water. I grabbed it from the bottom but now it seems like my gimbal is really loose. When I put the supporting plastic behind the camera, it doesn't fit like it used to. Should I be worried?
Also, when I turned the drone back on after this mishap, I had warnings of sensory issuers, gimbal warnings, but within a few seconds they went away.
Should I be worried or would my Mavic still be ok?
2017-2-23
geofox784
Flight distance : 1482175 ft
Warning in the flight status menu or warnings popping up on the main screen?
If it ain't broke dont fix it. Just try hover it for a bit and see if everything behaves.
2017-2-23
Youbdun12
They were warnings in the overall status
2017-2-24
Youbdun12
geofox784 Posted at 2017-2-23 17:28
They were warnings in the flight status not a pop up.
2017-2-24
hallmark007
Flight distance : 9827923 ft
Did it slip of its cradle, it should be held up by 3 little triangle things , if that's ok , I would do a gimbal calibration..
2017-2-24
fans90d4f438
Flight distance : 451335 ft
it's fine. Takes a bit of fiddling to get the gimbal clip 100% perfectly snug into that groove on the underside of the camera/slot on the gimbal holder/protector
2017-2-24
geofox784
Youbdun12 Posted at 2017-2-24 11:28
Thats normal for a few seconds after startup
2017-2-24
Youbdun12
https://youtu.be/_A0Ie9l3uj0
This is what my video looks like. Can someone help?
2017-3-3
Youbdun12
geofox784 Posted at 2017-2-24 13:52
2017-3-3
