Mark Guille
Flight distance : 2031818 ft
Jersey
Tom,
The app will make it clear when it wants you to calibrate the compass, it flashes up on screen that it needs to be done, you can't miss it. It cannot, however, tell the difference between needing a compass calibration and needing to be moved away from some hidden metal object so if you do ever get this message, before trying a compass calibration (probably right where the metal object is) ensure you are not anywhere near any metal, move the bird 6 feet or so away from the car, if you are on a concrete surface there may be steel rebars affecting the compass, get a friend to hold the drone aloft while you take off.
ONLY perform a calibration if all else fails.
The more you perform unnecessary calibrations, the more you risk getting a bad cal. If you don't calibrate when you need to, you may experience some lateral drift whereas bad calibrations are notoriously linked to flyaways, I know what I'd rather.
Those of you who prefer to calibrate whenever you are unsure, just to be, "on the safe side", are not actually, "on the safe side".
For those who insist on calibration whenever they fly in a different postcode, take look at this map. This should give you an idea where and how far you can go without compass deviations making a scrap of difference.
I'd rather be, "on the safe side"
