Sestaceans
Flight distance : 3963865 ft
Zlosnik Posted at 2017-2-25 05:02
But it doesn't matter. I put the camera in the ronin-mx, balanced it and put wings to up. I turned and still is the same. If ronin-mx is not connected to the m600 it looks the same.
The point is, why when you turn on ronin-mx, the axis PAN is not in themiddle.
I'll try to help you out.
1. Are you using your DJI Assistant Ap?
2. Have you done all of the following?
Restore Default Settings (since I take it you've never used it before except to screw around with?)
a.Calibrate your System?
b.Auto Tune Stablity in your Motor page on Assistant App
c. and I always do a balance test at the end.
Take the DJI tutorial on how to balance. It may not be centering up becuase it is compensating for the bar side of the gimbal, which would be countered by a camera.
I'm not being critical just honest. However if you are putting your gimbal on without a bracket and don't realize that it is a major stresser on the motors, you may need more practice before you fly that thing or it could be a lot of money down the drain.
