Inspire 1 1.10.01 Firmware upgrade fail
2197 7 2017-2-25
Heavydpj
Flight distance : 611027 ft
Actually, not even fail.  I don't get that far.  I have followed the tutorial to the letter.
I have downloaded the correct file from the Inspire 1 Support Website (Inspire 1 Firmware v01.10.01.40(X3)
I have re-formatted the Micro SD card
I have placed the .bin file (WM610_FW_V01.10.01.40.bin) on the card
I have inserted the card into the Inspire 1 X5
I Have turned on the aircraft
I have NOT turned on the remote controller
Every time, the Inspire 1 Pro goes through its opening sequence like normal. Without even an attempt at upgrading.
HELP!
2017-2-25
Henry M.Y.
Flight distance : 11548839 ft
You downloaded the wrong FW file, so could not upgrade your Inspire 1 Pro's FW.
In DJI's Inspire 1 download website, there is a pulldown menu where you should pull down and select Zenmuse X5, after which the correct download links will appear. The latest Inspire 1 Pro FW download "Inspire 1 Pro Firmware v1.10.1.40" has a filename of "WM610_FC550_V01.10.01.40.bin.zip". You have to upzip the file to extract the bin file for placing it into the Inspire 1 X5 and proceeding with the upgrade.
Henry
2017-2-25
DJI-Jamie
Flight distance : 112405 ft
Like Henry mentioned, you have to use the Inspire 1 Pro firmware if you have the X5 camera.
2017-2-25
Donnie Stugots
Flight distance : 3636782 ft
Henry M.Y. Posted at 2017-2-25 17:30
Nailed it Henry , 10 points for you my friend !!
donnie
2017-2-26
Heavydpj
Thanks gentlemen!  I was wondering why the file had (X3) at the end of it, and had a hunch that it may be the problem.  All is good to go now.
Again, MANY thanks!
2017-2-26
Fix
Nigeria
Hello, pls can I get a copy of the version 1.10 firmware
2017-9-1
Donnie *
Fix Posted at 2017-9-1 04:44
What camera system are you using X3, X5, X5 raw , etc ?
2017-9-1
RichJ53
Flight distance : 1837356 ft
Good eye Henry...
spot on!
Rich
2017-9-1
