fans48b00e55
Flight distance : 170597 ft
Just got a new Inspire 1. Batteries have never been charged. Right out of the box, one battery will not charge.
When checking level with one button push, LED 1 lights and then goes off to indicate 0-25% charge. Plug it in to charge and no lights turn on at all. If I press and hold the button for 5 seconds, all 4 lights turn on to indicate good capacity.
I did some reading and found the advice to remove the top and unplug the connector for an hour to reset. After that action, the battery responds when I plug in the charger, but all that happens is LED 4 blinks twice per second as if it thinks the temperature is too low to charge. Definitely not the case.
Anything else I can try, or does this battery just need to go back?
