Linh9
Flight distance : 28136 ft
Henry M.Y. Posted at 2017-2-27 05:53
Hi Linh9,
First, did you balance the Olympus 45mm lens as recommended by DJI with 2 balancing rings A and B? It needs a total of 14g at its front in order to perfectly balance the gimbal.
Thank you everyone for your help.
The DJI 2 balancing rings seemed like back order; thus, I am balancing with a filter and another ring, it seemed to balance fine.
I did what Mark suggested, set my shutter speed down to 1/60s, and the video on 45mm is much better. However, if I record in 4k at 60p and set shutter speed to 1/120s, doubling the frame rate, the jello effect is still there. Quite sensitive. Can I at least expect the frame to be stable at 1/120s?
Thanks,
Linh.
