P4P+ -- How do you get data logs from remote controller?
3506 8 2017-2-26
sd603
Flight distance : 274465 ft
When I hook the controller to my PC via USB cable, it shows up in devices as GL300E.  In Windows file explorer I see two USB drives when the controller is connected, however they are grayed out.
Any help would be appreciated.
2017-2-26
sd603
Anyone?  How about DJI representatives?  I crashed and want to upload the log.
2017-2-26
Phantom Help
Flight distance : 228255 ft
You can retrieve the logs by syncing them in DJI GO and then pulling them down by syncing them from a different mobile device that's running DJI GO. See this thread for more details.
2017-2-26
DJI Natalia
Flight distance : 318 ft
Sorry to hear about the crash, have you contacted our tech support to report the case?
As mentioned above, you can sync the flight records through DJI GO, then provide us APP account (e-mail) and the exact time it happened, our engineers will help you analyze it.
Also I do suggest you to send it in for evaluation and repair.
2017-2-26
sd603
DJI Natalia Posted at 2017-2-26 23:37
Hi Natalia,
Yes, I am able to and have synced the flight records to the DJI cloud.  I have initiated the return / replace / refresh process and have indicated "manufacturer defect".   I am now waiting for UPS shipping label which was indicated at 2 days.  So all of this process is in order.
So back to my original question, how can I DOWNLOAD the flight records from my remote control?  It seems like DJI has the process blocked.  Again, I can see the unit connected to Windows and when I go into Windows file explorer I can see two USB drives associated with the unit.  However, those USB drives are grayed out and can't be accessed.
The P4P and all other Phantoms have ability to access and download these files.  I can't on the P4P+ -- Is this a manufacturer's defect?  Should I be sending the remote control in for replacement as well?
2017-2-27
DJI Natalia
sd603 Posted at 2017-2-27 01:31
Hi Natalia,
You could not access to the log, please send in the remote together with the aircraft for evaluation.
2017-2-27
sd603
Ok, how do I change the current repair process to include remote?
2017-2-27
sd603
Natalia,
I am fine sending back controller once you indicate how I can modify current return (I got label today for 10lbs).
Question - the issue downloading flight data certainly seems like a software issue.  Can you confirm that your engineers can in fact download flight data from a P4P+ to a Windows 10 PC?
2017-2-27
sd603
sd603 Posted at 2017-2-27 10:53
Natalia,
Natalia,
I used the info provided by another poster in this thread to download my flight data.  Note that required I install DJI go on my phone and sync it with cloud and get data from my phone.  In a nutshell there is no way to download data directly from the + controller, you need to do this workaround.  Please report to product development and engineers a request to fix this defect in the + controller.
2017-2-28
