Donnie Stugots
Flight distance : 3636782 ft
Did you update the RC transmitter as well ? Depending on how many updates were skipped ( which is fine ) will determine If the RC will work with the current FW on the aircraft. . If you also updated the RC transmitter to 1.7.6 via the Go app you may simply need to do a re link with the RC and the AC. ( also the communication can just sometimes get lost for no apparent reason even if you Update the AC and RC properly, then just re link as well. )
Can you list the Current firmware on the RC ? Or if you have not updated it to 1.7.6 please do so , then you may need to re link the Ac to The RC ( This is done with the entire system ON and is located on the "Remote control settings" of the go app , in blue lettering Linking remote control , make sure you can find the Red link button inside the fuselage of the aircraft , just behind the top right silver nose cone screw of the aircraft, you do NOT need to take anything apart to find it , may need a flashlight though ) as well.
You own the Inspire 1 with x3 camera correct ?
ALWAYS UPDATE THE AIRCRAFT BEFORE THE RC TRANSMITTER AS WELL
donnie
