RicardoGray
Flight distance : 4356421 ft
Many discussions about this on the forum. Almost all of them will show some initial cracks around the underside of the motors at some point. If you have flown much at all and it is 8-months old, I'd say your right on track. some will tell you they have none, but I think most will say yes. As long as they don't get too big I don't think it is a problem. If you catch them early, you can try some product called Weld-4 on them. It is a clear solvent that when applied will actually fuse the crack together. I have done several including my own and it works very well. Actually seems stronger than before and stops the cracks. There are other solutions out there too, but this works very well. You can replace the shell, which I have also done but there is no improved shell to purchase, so you have the same thing only new, and at some point will probably crack again. Overall not a major concern. If you can catch them early and do something with them you should be able to go a long time.
Some say it is due to flying very aggressive, but I wouldn't consider myself in that category, but mine developed the cracks about 8-9 months in too. I never had a hard landing , always hand catching, and never crashed it. |
