Donnie Stugots
Flight distance : 3636782 ft
WYSEY Posted at 2017-3-1 12:45
Thanks for all your comments team. I was using my iPhone 6 as my mobile device. It was just an experiment ons. Nice long open road and I was the passenger. There was a storm cell an hour west but there wasn't much above. All the gps's were good with strong signal. My phone signal wasn't that great though, could this be a problem? The most confusing part for me was the fact that I had the home point set to the controller but it kept referring to the home point where we first started driving. I've got my distance set to 500 metres, I'd hit that and it would stop and hover. Donnie your screen shot looks identical except I hid the follow me function (not exited) mark it all made sense I my head until I read it. I must proof read things! I'll do a walk experiment next time. I just thought tje follow me function might work as good as say the mavic? Has anyone used it on moving cars? Or anything other than walking? Cheers guys
I have used it in my car ( moon roof ) with a driver and it worked great. ( lonely area, only a hermit lived up the ways ) It depends if the phone had strong GPS signal , try it in another area, not sure the cell signal would have anything to do with it , dont think so ( you use the same phone and go app with the mavic correct )
I would turn off the 500 meter distance limit in case it getting confused ( the gps ) , that could be the problem not sure .
Just try a walking test on a nice sunny day , it should work , then bump up to the car . The aircraft will turn and face the transmitter as well , just lower the tilt and it should keep you in frame also .
I am going to test mine again tomorrow , the weather is a bit dodgy today , but I will double check my settings and get back with you in a day or so .
Also I think the Follow mode automatically has a little Icon on the main go app page on the far left that shows the Person icon as the new home point so you dont need to change it , I will double check soon as weather permits.
Like I said I had the exact same symptoms , but it was a super heavy cloudy day .
Other members can of course chime in as well.
*** You can turn on the "hide" for the Pop Up - no problem , IF you get into any trouble the fastest way to kill the Follow mode and regain FULL control is to flip the Multi function switch from the F mode to the P mode , (you have sluggish limited control in the FM mode ( follow me ) ) so if you need to do something quick remeber this........TRUST ME
til' then
donnie
