New Osmo Moblie not charging - no lights, plugged in for hours
2353 7 2017-3-1
WOTS
Hi,
I just purchased a Osmo Mobile, read the instructions, then procceded to charge it all day without anything happening.
I have:
- Removed the clear plastic cover on the battery, and inserted the battery into the osmo
- Plugged the headphone jack side of the supplied charging cable into the osmo
- Plugged the USB side of the supplied charging cable into my macbook air USB port
- Left it plugged in all day (6+ hours)
So far no lights blink on the osmo indicating that it is charging and it wont power on.
Please help!
Thanks,
WOTS
2017-3-1
RWhis
Flight distance : 29334 ft
If you have a 2 amp charger (such as for the iPad) I would try using that instead of the computer usb port.
2017-3-1
WOTS
RWhis Posted at 2017-3-1 11:16
Thanks! That seems to have sorted it out..
Are you sure this is safe for the OSMO?
Also, how come it doesn't charge with the computer?
2017-3-1
RWhis
Not all USB ports are the same. Some allow you to charge devices, others are just for reading input into a computer from a device hooked to it.  Glad it worked out for you. My problem when I first got my Osmo was that I failed to notice the small plastic cover on the battery. Wasted a few hours until I figured that one out.
2017-3-1
Anand_C
India
Hey guys I am facing the same problem.
I guess I'm using the 2amp charger but I still don't see any lights.
I just received my DJI Osmo Mobile. Looks like a tough start here.
Can anyone help me out?
This is the charger I'm using. I also tried my iPhone 7 Plus charger, MacBook Air USB Port & Apple Watch Charger but nothing works.
2017-6-20
Anand_C
India
Ok it started working when I pushed the Battery inside.
Strange but it was done neatly properly and then to make it work I had to give effort to place the battery.
Anyways, Thanks!
2017-6-20
fansa7e391a5
Anand_C Posted at 2017-6-20 06:16
Mine died after a few months, but of course I did not get around to spending time to contact customer service but since it is now past 6 months (length of Battery warranty) my only option is to buy a new battery -- but how long will that one last. Anyone want to but a slightly use OSMO Mobile, lol
2017-7-31
Leoanaya
Flight distance : 4665 ft
Mexico
Having the same problem, not working doing anything you’d explained. What can I do?
2017-12-17
