djiuser_m6tUO4E5ERT9
fans0b2c9866 Posted at 2020-6-27 10:45
Hello, I also updated my Phantom 3 Pro Controller (GL300C) with the latest firmware as of 6/26/2020 18:00 EDT - i don't know the firmware level because I could not read it before it died. The firmware was updated by the DJI GO app on my iPhone via the USB connector. The remote was charged to 3 lights at the time (and was charging). After the update, the remote would no longer connect to my drone, despite multiple attempts to resync. I attempted to power it down - it refused for a bit, but eventually powered down. Now it no longer powers up. No charging lights, no beeps, no nothing. Pressing the power button 1 short, 1 long will not power it back on. This happened within 10 minutes of the firmware update (~ 18:10 6/26/2020). I see the reset process (press C1, C2, Shutter together and power it down). This method is useless, because the remote just won't power on to perform that reset. I left the remote as-is overnight, and it was warm all night long, despite having no power lights. What can I do? I see many people with this problem, and no resolution. I have a nice $1000 drone that is only useful as a pretty paperweight. Please help!!!
You have identical symptoms to myself, down to the controller becoming warm even though not in use. I was/am fortunate to having a unserviceable GL300B controller. So I stripped that down after first ensuring the battery was fully charged. Then did the same with the GL300C, checked the battery output and its was way down, so there must have been a power drain. I then connected this battery to the 300B controller and brought it back to full charge, as there was no indication on 300C of anything happening, So with 2 fully charged batteries i attempted the C1+Shutter route, fine it powered up as described. However, it will not connect either on its own or when the A/C is also powered up to the DJI GO App.I did attemempt a re-binding withut success. So I have one Doorstop Controller and one Faulty Controller. as these items are not cheap, even buy used, there is clearly a descrpancy in the term "SUPPORT" as defined by DJI. we are by no means the only users to have their controllers "Fried" by what appears to be a simple Firmware upgrade. (I wonder if DJI will respond to this or continue to play at being Ostriches) |
