FauxFilm
Officially it does not work with the Osmo Pro.
Unofficially... it does, and I use the gimbal extension cable with Osmo Pro sometimes. As-is the locking ring will NOT fit on the X5 camera, it won't engage and turn-to-lock because the ring is too "tall" for that camera. You'll have to do some machining, carefully remove the ring on the camera end of the extension cable (four tiny tiny screws inside it) and then carefully grind down the top of the ring (it's aluminum) until it will fit the camera. It took me several (maybe a half dozen) trial and error runs of grinding and re-assembling and testing until I had finally removed exactly enough material to make it fit (this is exactly the same process that some people were doing to the original Z Axis arm to get it to fit with the X5 camera, before DJI created a Z Axis arm specifically for the X5).
Keep in mind that you are now using a much-heavier camera that only attaches at the point of the connector (unlike the two structural points when you have the X5 on your handle) so I would be careful not to put TOO much stress on it... but it does work.
For what it is worth, you can also daisy chain the gimbal extension cables together... I use two of them connected together for a ten-foot reach. I'll probably buy another one to stretch that a bit more... I can't GUARANTEE that more can be successfully chained together... but two of them definitely work.
