Cougar1
Flight distance : 924393 ft
Dr Jon Posted at 2017-3-9 02:28
Its a complete GPS receiver with a much higher accuracy than that in the R/C or even the iPad. The iPad is +/- 1 meter this is better than 200 cm.
As an example if your in a chasing car mode and you need to A/C to come "home" you can even get it to land on the roof of the car you are using as it will track the forward motion of the GPS almost in real time. I have used it to land on a speed boat when it was in motion all i needed to do was bring it down and the forward motion was controlled by the GPS information being sent. For the cost involved i like it very much, but i suppose it depends on your needs. For some reason all my assignments involve some sort of action or motion. I'm sure you get the idea.
Dr Jon, re: higher accuracy, I am a bit confused about this statement, you are indicating the iPad has +/- 1 meter, so that would be within 200 cm, so how accurate is the GPS module? In order for it to be better it needs to be less then 200cm? Am I misunderstanding? |
