Matt-and-Riley
Flight distance : 324442 ft
I think there is a hill on your horizon? The left is higher than the right..
Even if you think there is no wind, there is, always, especially up higher. To hover in place the drone must tilt into the wind a bit. The gimbal should adjust for this giving a straight image. But all drone gimbals seem to suffer from tilt. Certain moves will make it worse such as flying sideways and turning quickly.
It's an issue we all live with and most of us fix after. If you're filming in 2.7 or 4 and exporting at 1080 then you can zoom in a little, rotate the video till it's straight.
To test the wind put in ATTI and watch it drift away |
