Bullflyer
Geebax Posted at 2017-3-4 14:43
No, that is not true, you cannot switch off the GPS, it will always know where it is if it is able to receive satellites. And it can refuse to startt up if it knows it is inside a NFZ.
The best solution to this probloem is to use a non-DJI aircraft that does not implement a GEO system.
No, what you say is not right. If you block the reception of the GPS antenna, as Labroides says, the Phantom does not know where it is. I've seen it done before, and it worked. |
