Check out this video for details....
All you need for this stand:
Parts list for OSMO stand 1 stick (10feet – you will have some left over) of ¾” schedule 40 PVC pipe. Cut the stick into the following: 9 pieces (4.5 inches each) 6 pieces (1.5 inches each) 6 ¾ inch schedule 40 PVC tee’s 4 ¾ inch schedule 40 PVC elbows 1 2 inch to ¾ inch outlet schedule 40 cross (slip – not threaded) 3 ¾ inch caps 1 inch tubular pipe insulation ( foam – this usually comes in a 6 foot length) 1 can (small as you can find) of medium clear PVC cement (glue) 1 package of Velcro (your choice on size) 2 rolls (depends on size) of cloth tape (your choice of color) Tools needed: PVC pipe cutter (hand tool) or you can use a hack saw. Vice is helpful but you can also just use a hack saw and hold on to the pipe, this is much more difficult.
