3D Photogrammetry App with Mavic
12407 10 2017-3-6
rick39
Flight distance : 164354 ft
If you have tried using the Mavic for creating 3D aerial imagery, what app are you using and how are the results?
The reason I ask is that I find the genre fascinating having dabbled very briefly with Altizure. The cost of processing these images seems to vary greatly, but as a starting point, Altizure seems a good place to try as it has a free option albeit with limitations.. I want to try Both Dronedeploy and Agisoft. The standard paid version of Agisoft is probably the least expensive, but the trial version is severely time limited. Dronedeploy seems to be one of the best Apps but is cripplingly expensive.
I understand that to get the best results it is necessary to add oblique images shot as a POI as well as the standard grid images shot with the camera facing straight down. This being the case,  how does the the GPS meta data work flying a POI mission when the subject target camera view is not the grid reference relative to where the drone is capturing these images. Grid view shots will be fine as the drone is flying directly over what it "sees".
2017-3-6
K4Unl
Flight distance : 122175 ft
Gonna just poke a message here as i am really interested too!
2017-3-6
DRONE-flies-YOU
Flight distance : 1450594 ft
The Flitetest guys (YouTube) did EXACTLY this (did many Dronedeploy mappings following up with a POI to get lower level imagery).  As long as it's not over the 999 image limit.  ***The huge issue is JPEG imagery out of the Mavic.  Since the JPEGs look like garbage, any 3D mapping will look like crap.
2017-3-6
rick39
A rough and ready first attempt here using Altizure without any oblique images, just a series of overhead grid captures. Sure, it looks a bit "impressionist" close up, but there's room for improvement. Not sure how Altizure copes with the focus options on the Mavic camera.
https://www.altizure.com/project/58bb0264ca86f5500a91c919/model
2017-3-6
QuantX
Flight distance : 356542 ft
rick39 Posted at 2017-3-6 04:39
I'm interested to find the results of this.  Especially since I've been using dronedeploy and pix4d with my mavic and gotten pretty good results so far, but definitely want to improve the quality.
2017-3-21
Richard Mavic p
Flight distance : 44797 ft
+1 Would like to try 3d mapping with mavic too. which app to go?
2017-3-21
rick39
I haven't got anything to compare,  but I'm pretty pleased with the results I've been getting from Altizure.
https://www.altizure.com/project/58c556d74a69c5560614e60e/model
2017-3-21
Balaes
Flight distance : 14241171 ft
Romania
https://www.altizure.com/project/58dbb4a4614c3f224c68e53e/model
with Phantom 3S
2017-3-29
MissionNorth
Flight distance : 18031 ft
Balaes Posted at 2017-3-29 23:45
with Phantom 3S
That poly tunnel needs attention.
2017-3-30
fansc29f0729
Flight distance : 121880 ft
Dominican Republic
Phantom 4 and Pix4D
[url]https://cloud.pix4d.com/pro/project/124944/map?shareToken=5e97119983d7453ab9c4098b7c165286
[/url]
2017-11-22
karwengng78
hi there - what type of mavic did you use? I have a mavic air and want to give photogrammetry a go!
2020-5-8
