My Controller Charge only lasts one flight
1002 12 2017-3-5
King Sirloin
Flight distance : 136453 ft
Been powering up the controller and mavic indoors to familiarise myself with the app and settings while watching youtube guides.  I've found the controller charge drops 'at the same rate' as the battery on the mavic.  I have a Samsung Galaxy Note 10.1 plugged into it via the USB on the bottom of the controller.
I'm going to test a Galaxy S5 phone via the side plug tonight, but most likely visiting the shop again asap.   There's no point in having 3 mavic batteries if the controller only lasts 27 mins.
Also, does anyone else think warranty replacements from the shop should take priority over pre-orders for faulty goods?  I don't like the prospect of waiting for replacement goods after waiting 1/3 of a year for the Mavic.  I've only had it 5 days and no outdoor flights yet (rain).
2017-3-5
Flyboyz
Flight distance : 142615 ft
Singapore
Should not, i fully charge my controller and can last at least 4 flights but there is still juice left but i charge again anyway...
2017-3-6
chippie
Flight distance : 12976 ft
Android devices suck charge from the controller however it should still not be draining it at that rate. I was getting ~3 batteries with my S6 or S7 however these are not tablets which depending on the battery size may suck more power from the controller of course. The device should actually suck less power via the bottom port than the side port also.
Few things I would try:
. A different cable to make sure it is not faulty and half the problem.
. Are you able to borrow an iPhone or iPad, these devices do nto drain the controllers battery and will give you a good indication if the actuall controllers battery may be faulty if the controller still drains fast whilst usig them.
If the controler does not drain the same with the phone you tried or an iOS device then it is most likely the Tab that is doing it otherwise I would say a fautly battery in the controller. I get 7 to 9 batteries worth with my iPand Mini 4.
Let us know how you get on.
2017-3-6
King Sirloin
Tried with my Galaxy S5.  60% controller battery drained to one full flight battery.  So the extra screen size of the Galaxy Note might account for the total battery drain while using it.   Going back to shop with it asap.
2017-3-6
Flyboyz
Singapore
Btw i m on iPhone 6 plus..
2017-3-6
Ex Machina
Flight distance : 1806362 ft
I think I read somewhere that on Android you can change the type of USB connection you have to one that does not ask for juice -- you might look into that before starting the replacement process. Good luck.
2017-3-6
rparge
Flight distance : 173852 ft
Try flying without the video device, it is not needed on the Mavic, then you would know for sure.
2017-3-6
R&L Aerial
Flight distance : 298100 ft
Settings, click USB debugging, fixed.
2017-3-6
King Sirloin
R&L Aerial  Posted at 2017-3-6 09:22
Settings in what?  Controller or phone, coz my phone has nothing like that.
2017-3-6
R&L Aerial
King Sirloin Posted at 2017-3-6 13:41
Go to settings on android tablet or phone, click on about phone, click on build number then tap build number 7 times to enable developer options . Then click on developer options check the box that says USB debugging. Should take care of your battery drain problem.
2017-3-6
Jake Phantom 3
Flight distance : 2639747 ft
R&L Aerial  Posted at 2017-3-6 15:15
Should you have the remote on also when you try this fix?
2017-3-6
King Sirloin
Tried that setting, no improvement.  Returned to shop.  Was having other issues too so they recorded it as a DOA.  I will get a priority replacement over a pre-order when they get approval from DJI.
Thanks for the advice.
2017-3-6
jims3000
turn off rapid charge if your tablet or phone has it turned on
2017-3-6
