OSMO not finding OSMO WIFI
1513 6 2017-3-6
fans3d037974
Okay every since I've had the osmo handle and added my x5 camera w/adaptor when I'm at home the osmo won't find the osmo wifi I have a S7 egde and just updated to the latest software but these issues I've had before the update. Now today I bring my osmo into work today and it works just fine so I'm not sure why if won't connect while I'm at home?
2017-3-6
Matt-and-Riley
Flight distance : 324442 ft
Is your home network overriding the osmo network, I get this a lot, have to tell the phone to forget my home network..
Or can you just not see the Osmo network in your phone settings at all ?
2017-3-6
fans3d037974
Matt-and-Riley Posted at 2017-3-6 11:10
No I can't only see the Osmo network, prior to updating my Samsung s7 edge I would be able to see all networks around but with the new sw it only shows my home network.
2017-3-6
Matt-and-Riley
fans3d037974 Posted at 2017-3-6 11:44
Oh, hoping for a simple fix.. I had a Samsung for a while and had to do numerous hard resets and cache resets when it misbehaved, often 'smart' network related, but that was more about dropping connections.
I'd be tempted to a reset of everything.
2017-3-6
fans3d037974
Matt-and-Riley Posted at 2017-3-6 12:01
I think it's the new update that I just preformed because in the old sw in the wifi tab you can see all available networks but now it doesn't have that feature anymore I'll have to figure out if it can be turned on. But it does work away from my home.
2017-3-6
DJI-Ken
Flight distance : 1515312 ft
fans3d037974 Posted at 2017-3-6 12:34
When it connects to your home network if you forget the network will it then connect the Osmo to your phone?
2017-3-8
fans4ebd70e9
Indonesia
Somebody pls help. My OSMO wifi not appear in my network list. I use iphone 5S with IOS 10.2.
I've tried thetroubleshoot by holding triger and shutter and hold down the power, still no effect.
Also when I turn on the osmo, power indicator turn green only for seconds, no indicator of running fan, then led indicator turn red again.
2017-5-6
