TheMann58
Flight distance : 18669501 ft
Vayreda Posted at 2017-3-31 15:37
Hi, i'am new on this forum and i have a question about the firmware. I got a P4P and two batterys, after the firmware, does the second battery automatic gets the firmware just putting the battery in the aircraft? Or do i have to repeat step by step the upgrade from the firmware for each battery? Tnx
When you insert each of your other batteries into the P4Pro aircraft and power it on, you should get a message on the main page of the DJI GO 4 app saying "Inconsistent Firmware Found" and asking if you want to upgrade the firmware. Swipe to the right to start the firmware upgrade and your battery firmware will be updated in less than 45 seconds. If you have additional batteries that require firmware updates, power down the aircraft, insert the next battery, and repeat this process. NOTE: not all firmware updates include battery firmware updates. Firmware updates can include one or more of the following: aircraft flight control firmware update, aircraft motor ESC firmware update, camera firmware update, gimbal firmware update, battery firmware update, possibly others. |
