New Phantom 4 Pro Aircraft Firmware V 01.03.0418 07MAR2017
12Next >
3466 41 2017-3-7 11:26:39
TheMann58
Intern Pilot
Flight distance : 2583529
Please use this thread for all user feedback and comments on new Phantom 4 Pro / Pro+ Firmware version V 01.03.0418 07MAR2017
Phantom 4 Pro/Pro+ Release Notes  http://www.dji.com/phantom-4-proCopyright © 2017 DJI All Rights Reserved.
Date : 2017.03.07
Aircraft Firmware : V 01.03.0418
Phantom 4 Pro Remote Controller Firmware : V 1.4.0.0
Phantom 4 Pro+ Remote Controller Firmware : V 1.1.3.0
DJI GO 4 App iOS : V 4.0.5 DJI GO 4 App Android : V 4.0.4
What’s New?
 Updated No-Fly Zone Management.
 Added lock gimbal function to fix the gimbal to its current position.
 Added AFC function to support continuous auto focus when switching between scenes.
 Upgraded D-Log color mode to extend dynamic range.
Questions to P4Pro Users - does this firmware address the following reported issues (even though they are NOT listed in the What's New list):
- P4Pro rising above programmed RTH height on some RTH return flights
- Gimbal horizon level during hover (after IMU and gimbal calibrations) but tilting with increasing speed forwards or sideways
- Frequent erroneous High Wind Warnings
Any other fixes?
Any new Features?
2017-3-7 11:26:39
Woodwanger
Student Pilot
Along with the P4 Pro + issues....lag and app crashing!
2017-3-7 11:37:55
fans7efcc3c6
Hobbyist
Hungary
P4P lag when 4k recording..........There  are half years error and P4P useless without 4k recording.
One month and P5 ...................
2017-3-7 11:46:43
CyFA
Hobbyist
Flight distance : 95962
Cyprus
or losing signal and lagging
or overexposed photos
or vanished photos
oh ... and dear DJI, try to record, then press play to see if they are there (video will not play to see it) and then go back to live view ... its blank!
Solution: You then need to go back in to play and exit then press photo to get it back. Not very nice while in a flight.
PS: did all calibrations and using an Android. ;)
2017-3-7 11:47:02
piowoc73
Student Pilot
Is anybody from DJI able to elaborate about "Updated No-Fly Zone Management"? I would be really interested to learn more details.
2017-3-7 13:20:11
Eric13
Intern Pilot
Flight distance : 189835
piowoc73 Posted at 2017-3-7 13:20
Yes - I would be interested as well. It is a separate, optional update after todays firmware upgrade.
Interesting that this update is not a MUST. I haven't install it yet.
2017-3-7 13:28:38
piowoc73
Student Pilot
Eric13 Posted at 2017-3-7 13:28
How do I get to this screen in the app?
2017-3-7 15:23:19
J_L Drones
Beginner
I found a somewhat temp fix for the issue with the lag. I noticed that when I format the sd card from the dji app everytime im going to fly i experience almost no lag
2017-3-7 15:52:58
J_L Drones
Beginner
Let me know if this helps
2017-3-7 15:53:12
Eric13
Intern Pilot
piowoc73 Posted at 2017-3-7 15:23
That screen appears after completion of firmware upgrade - at least ony my device being an Android.
2017-3-7 16:04:16
AdrianoGosy
Beginner
Brazil
Friends, I did 3 things that turned out positively, I do not know which one made it work, but it worked!
1 downloaded the file with the dji page set to the first oriental language (Chinese I think)
2 formatted the SD that was in FAT for EXFAT
3 I connected the rc in the charger
Finally everything worked out !!!
Thank you for your help
2017-3-7 17:54:02
piowoc73
Student Pilot
Eric13 Posted at 2017-3-7 16:04
I updated it with DJI assistant on my PC, so I haven't even run the app. When it was done I connected the drone to the RC, but there was no such message, so now I don't even know if the NFZ database has been also updated, or not.  I wish DHI planned it in a more user controllable way.
2017-3-7 20:08:50
JayOne
Hobbyist
what kind of restrictions we are going to have with this update???
2017-3-7 20:58:17
Helimage
Student Pilot
Flight distance : 43934
Finland
I think the gimbal issues cannot be fixed with a firmware update, it's simply bad hardware. Better luck with the next model. Also, the reason for constant wind warnings might be that DJI can expire your warranty in every single case and say: "It was a pilot error, the app clearly showed a wind warning." Who knows.
2017-3-7 21:47:58
kykphantom
Student Pilot
Flight distance : 926333
Cyprus
Can somebody explain in more detail the above function?
2017-3-7 22:39:41
PKPhantom
Student Pilot
Flight distance : 83904
**Added lock gimbal function to fix the gimbal to its current position***
This is what interests me the most.  I would also like to know exactly what this means? Is the HORIZON TILT problem finally addressed on this firmware update?
I can handle the rest of the problems. But HORIZON TILT? No way!
2017-3-7 23:08:04
JoiCam
Student Pilot
Flight distance : 42815
Iceland
I also would like to know what this lock gimbal function does.
2017-3-8 00:23:23
Viridis
Student Pilot
Flight distance : 149910
If the gimbal is still following the aircraft movement, or pitching, it locks it whilst image is taken, then resumes it's path of movement,
2017-3-8 02:22:31
stalker
Hobbyist
Flight distance : 4155
Viridis Posted at 2017-3-8 02:22
So far no issues here. Fingers crossed!
2017-3-8 02:27:40
stalker
Hobbyist
2017-3-8 02:26:20
JoiCam
Student Pilot
Iceland
Thanks Viridis
I will also have my fingers crossed and do the upgrade to night.
2017-3-8 02:57:56
ROBERTO SMERA
Hobbyist
Flight distance : 1198049
Brazil
CyFA Posted at 2017-3-7 11:47
or vanished photos
Hi CyFa,
The overexposure issue seems to be fixed on my Phantom. Tried the camera yesterday after updating and the pictures were perfectly exposed.
2017-3-8 03:33:05
kykphantom
Student Pilot
Cyprus
PKPhantom Posted at 2017-3-7 23:08
I am sorry, no good news for you. TILTED HORIZON is still a problem, even after the latest firmware upgrade, IMU calibration, etc...
2017-3-8 09:39:31
UltraDan
Hobbyist
kykphantom Posted at 2017-3-8 09:39
even with gimbal lock?
2017-3-8 09:52:30
P4P+
Student Pilot
It is strange that they fixed problems that noone has had. I suppose the continuous auto focus will eliminate the need to tap to focus on close subjects, so there is that.
2017-3-8 09:59:44
P4P+
Student Pilot
P4P+ Posted at 2017-3-8 09:59
I bad! There was no lag our breakup when recording in 4K 30 so that seems to be fixed and the active track record mode seems to be fixed. I will have to recharge and run another test to make sure it is not just luck.
2017-3-8 10:24:32
P4P+
Student Pilot
P4P+ Posted at 2017-3-8 10:24
The video size switching does still occur when going into active track mode, so that is the same as it was. BUT no more laggy/artifacty 4k transmission on the screen while recording in 4K!
2017-3-8 12:07:18
PKPhantom
Student Pilot
That's a real bummer! I was all excited for nothing. SMH
2017-3-8 12:08:14
P4P+
Student Pilot
To note, the update now has the screen showing the actual color name instead of calling them Film-x.  I tried dlog but to me it looked very over exposed.
2017-3-8 12:08:51
RodneyDangerous
Banned
2017-3-8 12:36:48
UltraDan
Hobbyist
What I can't understand is why can't you just map the horizon gimbal tilt to one of the scroll wheels so you can adjust it on the fly when it starts to move? I think Dji have missed a trick here.
2017-3-8 12:41:05
PhantomPhil
Hobbyist
Flight distance : 6829
piowoc73 Posted at 2017-3-7 20:08
For P4P+
You can only update the NFZ database if you have installed DJI Assistant 2 V1.1 that is available on the Phantom 4 Pro downloads section of the DJI website. Connect your aircraft to PC and run Assistant 2 V1.1 and the NFZ database update screen will automatically appear giving you the choice to install or ignore.
2017-3-8 12:52:04
fansba0fd9bf
Beginner
Flight distance : 23665
So despite some of the issues that weren't addressed or fixed in this release.    Has anyone actually flown their P4P without any problems after updating?
2017-3-8 13:33:51
theGrindLab.com
Intern Pilot
Flight distance : 317007
fansba0fd9bf Posted at 2017-3-8 13:33
Not me. I just flew mine with the latest update on my Shield K1 running Android 6. Video feed artifacts and grey rectangles cover a third of the screen intermittently. Disabling video cache helps but artifacts still show sometimes.
2017-3-8 15:49:44
Eric13
Intern Pilot
UltraDan Posted at 2017-3-8 12:41
Litchi offers that option:
C2 button hold + exposure compensation dial
2017-3-12 10:58:17
stalker
Hobbyist
One flight after update, but I skipped the No-Fly Zone database update. Flawless flight with GS Pro. Very stable, no tilted horizon (but I never had any issues there).
2017-3-12 13:02:31
Eric13
Intern Pilot
I made several flights in the past two days having the latest updates:
- No changes regarding horizon tilt problem.
- App crashed once while being airborne which ended in tablet restarting (Nvidia K1 with Marshmallow)! Only RTH button saved the bird.
- No changes regarding video lag on screen. Tried numerous options regarding SD cards, formatting from within the app, caching disabled, no screen recording, stopping all other processes on the tablet.
- "Large Wind Velocity Warning" seems to be realistic now. It ocurred in calm winds when I suddenly stopped horizontal flying in P-mode. The jolt that came with it was apparently registered by the system as wind gusts.
I had wind warnings today while flying in Bft 4 winds and I guess those warnings are justified :-)
Aah - I forgot: I dont get these messages anymore: "Breaking now. Return sticks to midpoints first"
Having read a lot in other forums in the past days it appears that main issues have not been resolved. No major overhaul at all.
Still I love my Phantom. I will struggle - her and I will get through this. I don't let these issues get me down.
2017-3-12 14:06:36
airspace_media
Student Pilot
Flight distance : 58
if you hold C2 and use the right scroll wheel you can adjust do a gimbal horizon adjustment but it doesn't always stick 100%
2017-3-13 04:07:11
Punchbuggy
Intern Pilot
Flight distance : 73489
I took my P4P (with new firmware) up twice last weekend, and videoed for each whole session. No problems with the flights - very responsive and it went where I wanted. There was a momentary hiccup with video connection, but that was it - craft was never more than 250m away from me anyway, but I was flying near a hill with some serious telecomm dishes so I expected the worst.
One thing I was very happy about was the video quality - everything stayed sharp (due to AFC?) and the horizon perfectly level through-out despite some tight turns and stops.  Sadly, I couldn't say the same thing for my P4 - horizon was out-of-whack for most of its flight...
Firmware update was done using Assistant 2 v1.1.0 on the PC (I Never update craft via controller), and update initiated as soon after the craft is turned on as I can achieve (so it's never hot). Only calibration I did following was for VPS, then on a flat surface for the gimbal. It didn't need IMU nor compass, so wasn't done.
2017-3-13 14:04:49
Arimese
Beginner
Flight distance : 242310
Losing signal this is 6 of 6 really and I'm on a vacation for this purpose
2017-3-14 20:25:57
12Next >
Close
DJI RecommendsPrevious /1 Next
