RONIN MX out of control after firmware update CGU 1.4 and IMU 2.3
2037 7 2017-3-8
Richard Pichler
Flight distance : 153494 ft
Austria
Hi all,
yesterday suddenly I had a problem with the tilt axis of my Ronin MX. There were loud vibrations and the engine became extremely hot.  Then I used the functions "Calibrate System" and "Auto Tune Stability" in the DJI Assistan  to solve the problem, but no result. Then I  made a firmware upgrade (CGU, IMU). Now the Gimbal is completely out of control and turns in all directions. I have to hold it to avoid damage. The setup was the same as always. Same camera, well balanced, the problem came without warning from one day to the other.
Any ideas ;-)?
Thanks Richard
2017-3-8
kriegs
Same here. Lmk if you find an issue.
2017-3-14
Richard Pichler
Austria
kriegs Posted at 2017-3-14 06:44
I sent it to DJI :-)
2017-3-15
fans3ff297e6
North Macedonia
And we have this problem
2017-5-11
DJI-Jamie
Flight distance : 112405 ft
Could you clarify what troubleshooting you've done thus far to try and rectify it? Have you contacted the Support team about this as well?
2017-5-11
Zlosnik
Flight distance : 33117 ft
Poland
Accurately. A few days ago ronin-mx returned from service Dji in Germany. They calibrated it and centered in each axis. I ran it probably 3 times and after taking a calibration process started to happen the same things.
2017-5-12
fansdeeaf14c
Flight distance : 877552 ft
Poland
I have same problem, did you sloved this issue?
2017-11-8
farek
Poland
This is how it looks like. I have tried everything (update, calibrate and it is perfectly balanced)
DJI What is wrong!
2017-11-8
