thomasakira
Flight distance : 921693 ft
I 2 Fly Posted at 2017-3-10 11:10
Very difficult to see the issue in Vimeo. Maybe an irrelevant question, but I had a lot of "flicker" issues flying over reeds - like you did - and then saw "flicker". Did you check the sharpness in your video setting? Try it on -1 and see if this does not help..... Regards.
Thanks for the suggestion, but this is a raw dng file. Do you mean reduce sharpness in davinci? I did, give that a try...sharpness, contrast, and curve adjustment create the most pronounced changes in the visibility of the flicker...but reducing these variables a) does not kill the flicker and b) does not produce aesthetically pleasing results to me. |
