Bando Works
Flight distance : 253704 ft
Linh9 Posted at 2017-3-10 16:54
Thank you for the information. This helps a lot. Mine has issue in 4k@60fps with 1/120s. Will have to send my x5s in for replacement.
One more question if you don't mind, what do you use to balance your 45mm?
DJI offers balancing rings for compatible lenses. The rings for the 45mm come in a pair, one outer ring and one inner ring. We removed the outer ring and replaced it with a Tiffen ND 0.9 to allow for the proper exposure and still maintain equal balance. Hope this helps! Cheers |
