Lost my Mavic
2615 26 2017-3-10
KevDrones
Flight distance : 475522 ft
Guys wanted to let you know that I lost my Mavic. Be careful of using point of Interest and then losing connection.For some reason I lost connection at 1.5 km from lauch point. I was in a car like 500 meters from it. In sight. I had the windows open and was looking at it. Then it went of course and I was still up and it lower attitute and went into a mountain range that is closed. Beware of using point of interest.
2017-3-10
Eyesaround
Flight distance : 271010 ft
Chile
More info? Can you upload you flight log?
2017-3-10
hallmark007
Flight distance : 9812789 ft
Seems strange, your logs will help see what might have gone wrong, were you in the car with controller?
2017-3-10
DJI-Ken
Flight distance : 1515312 ft
If you sync your flight records and provide your email used with the GO app I will review the flight to see if I see anything unusual.
The Mavic is a very reliable aircraft, it's strange that losing connection during POI would make it go in a different direction then the home point.And sorry that you lost your aircraft.
2017-3-10
fansc2962bbc
Flight distance : 29452 ft
Sweden
Yes the Mavic is really very reliable
2017-3-10
KevDrones
It is not reliable. I have already synced it. With the same forum email.
2017-3-10
rydfree41
Flight distance : 153268 ft
Not like the inside of a car is like a Faraday cage or anything .
2017-3-10
mewchi
Flight distance : 614931 ft
I have found it to be extremely reliable.  I have logged over 50 flights and 40 miles with mine without a hiccup.  The key issue may be being in a car.  Like someone said before it is like a faraday cage.
2017-3-10
KevDrones
My antennas where pointed properly outside the window straight out at the Mavic.
2017-3-10
DRONE-flies-YOU
Flight distance : 1450594 ft
rydfree41 Posted at 2017-3-10 14:52
Exactly, it isn't.  New cars are manufactured using less metal.  He also said he had big holes in your faraday cage (windows open).  So the small wavelength of 2.4Ghz easily gets inside that big window opening.  Also, a faraday cage is more for the EM waves, which you probably already know.
2017-3-10
DRONE-flies-YOU
KevDrones Posted at 2017-3-10 16:38
I am curious if the Mavic continued to log the disconnect.  I've had this happen & looking at the logs revealed that the Mavic stopped logging 3 minutes prior!  This was after using Activetrack & Cinematic Modes during a flight on FW x.x.300.
2017-3-10
KevDrones
I think it is the software because I was at 70% battery and launched at 100%. So it wont just land.
2017-3-10
yoengel
Flight distance : 2370988 ft
Your antennas are supposed to be perpendicular to the Mavic, not pointed at it.
2017-3-10
KevDrones
I know like 45 degrees. Read the manual.
2017-3-10
DJI-Jamie
Flight distance : 112405 ft
I'm sorry for your loss. There can be a lot of factors at play when you're in a car and not out in the open. DJI will look at the logs and see whether or not it's anything can can be covered under warranty.
2017-3-10
rydfree41
DRONE-flies-YOU Posted at 2017-3-10 16:59
I've tested my Taranis and a friends Futaba 2.4 by placing it in range test mode and the signals went to crap when we sat in the car . We were going to use a QAV500 drone a couple years ago to fly over some of the guys muddin' in 4 wheel drives but did not chance it because of the signal .
2017-3-11
GMG
Flight distance : 3632605 ft
mewchi Posted at 2017-3-10 15:13
I thought the same until I had about 90kms and 60 flights on the clock.  But a sudden shift from 19 satellites on 5 bar signal strength to ATTI mode at low altitude in the wind certainly knocks your faith.  It only needs to happen once.
2017-3-11
MDSH
Flight distance : 334869 ft
GMG Posted at 2017-3-11 12:21
"But a sudden shift from 19 satellites on 5 bar signal strength to ATTI mode ... certainly knocks your faith.  It only needs to happen once."Been there...
If only there was a way to practice ATTI mode.
2017-3-11
hallmark007
KevDrones Posted at 2017-3-10 17:37
You were 1.5 k from take off position, 500 meters from Mavic driving in a car with your hands out the window, shooting in POI .
I'm completely baffled from 500 meters you had VLOS and you were filming a POI, it's extremely difficult to see Mavic from 500 meters, but to set a POI from 1.5k how do you do this.
Maybe if you post your logs we can understand a little more..
2017-3-11
seeker_ktf_
Flight distance : 218474 ft
hallmark007 Posted at 2017-3-11 18:11
It's not hard at all to see the Mavic from 500 meters on a clear, sunny day.  I find the dark color much easier to spot against a bright sky than the white of the phantoms.
That point notwithstanding, I hope we get to see the logs.  If it really lost connection, then the flying into the mountains was surely RTH activating and then flying back straight towards the home point.
I'd really like to know how this turns out.  Here in the US it's against the law to fly a drone from a moving vehicle on land, but I've been experimenting with it from a moving boat and I could sort of see this kind of thing happening to me in that mode.
2017-3-11
KevDrones
I had it is sight, I saw it crash.
2017-3-11
hallmark007
seeker_ktf_ Posted at 2017-3-11 19:24
I have read many crashes here, regarding flying active track and POI, I haven't seen any yet where dji has not claimed pilot error, these methods of flying are all auto pilot, but can be cancelled very simply, if radio signal is lost then the Mavic should return home hover or return to remote if pilot or just land. That fact that op saw it crash is very unusual.
If it lost gps that's a very different thing, it would just drift until it crashes or runs out of battery. The op has not said he lost gps, so I think it would be good to know what happened here, so that's why I asked op twice to put up logs...
2017-3-12
KevDrones
I just lost connection and then after the crash on the mountain I got connection. How does that even work?
2017-3-12
mewchi
Modern cars also have lots of interference being generated off of them.  My audi has a built in wifi hotspot which could also interfere.  Then you include ignition system leakage, TPMS signals and whatever else the car has for features and the variables just grow from there.  Windows don't always represent an opening in the cage as well.  Some cars have windows and windshields with coatings that interfere with radio signals. For instance I have an SUV that the fastrak transponder doesn't work in because of the windshield coating.  The way I see it is the world has too many unknown signals to always go just blaming it on DJI.  Pick up an SDR and scan the band and see what I mean.  It's a crowded world.
2017-3-12
hallmark007
KevDrones Posted at 2017-3-12 10:54
Hi KevDrones if you want to know what happened, just put logs up.
http://www.phantomhelp.com/Phantom-4/#DataLog
2017-3-12
Poop Chute
KevDrones Posted at 2017-3-10 14:40
My Mavic has over 100 long flights, including complex Litchi missions.  She runs the same missions as her larger siblings.  No issues other than being difficult to focus in low light conditions.
2017-3-12
Beamer
Flight distance : 597096 ft
I too just lost my Mavic today for no good reason. It just disappeared. /Users/stevebeamer/Downloads/IMG_7459.PNG
Support. please check my flight logs and see that it must be a system malfuction. spambeamer@gmail.com
2017-3-12
