Datalink?
1459 8 2017-3-11
fans5a05ffa9
Flight distance : 157539 ft
S800 EVO
A2
Lightbridge 1
Z15-BMPCC
Can I add Datalink to this setup?
2017-3-11
ricci2
Flight distance : 61158 ft
Your sure can, I found out the hard way and bought a datalink for the A3 with bluetooth and it will not work with the A3 but will for the A2,,,I have a new one in a box if you want it?
Ricci
2017-3-11
fans5a05ffa9
ricci2 Posted at 2017-3-11 11:04
Ricci
Thanks Ricci,
I actually have one.  Just figuring out what to put it on.
I was worried about 2.4G conflicting with LB.
2017-3-11
ricci2
fans5a05ffa9 Posted at 2017-3-11 12:17
Thanks Ricci,
Hi,
The standard M600 runs 5.8 and 2.4 with no issues so far,  some are running third party transmitters as well as the DJI controller for gimbals .
ricci
2017-3-11
DJI-Jamie
Flight distance : 112405 ft
Thanks Ricci,
It's really not recommended to use the 2.4 Datalink with LB1, as their channel hopping abilities are quite similar and have a tendency to interfere more often. It would be better to switch the FPV system to something standard, like a 5.8 GHz system.
2017-3-11
DJI-Jamie
ricci2 Posted at 2017-3-11 14:44
Hi,
Lightbridge 2 has a different channel hoping strength compared to the LB1, so it's a tad different.
2017-3-11
ricci2
Hello,
Looks like Jamie has the best answer here, thank goodness someone know what they are talking about.
I did not read where it said LB1, apologies.
ricci
2017-3-12
c53steeler
Hi!  I had a question on how the A3 works.  I currently have the A2, and it needs a 2.4GHz datalink.  The A3 is not compatible with that, but does not seem to have any replacement for it.  I am not running the D-RTK, and I do not have the Datalink Pro.  So how was the 2.4GHz datalink replaced?  I am using the Lightbridge 2.  I can only assume somehow the data that was going through the 2.4GHz datalink with the A2 is now going through the Lightbridge 2, but I do not understand how that is possible.  Any clarification would be great! Thanks!
2017-6-15
DJI-Jamie
c53steeler Posted at 2017-6-15 05:57
I responded to your own thread regarding this.
2017-6-15
