NoSale
Flight distance : 460958 ft
I'm in the early stages of determining which filters to get mysekf. ND filters will be beneficial to videos, and as ex Machina states, are intended to knock down shutter speed. This adds a slight amount of blur to motion giving a more cinematic feel. Otherwise, in bright light, you get very sharp, but unnatural motion. Regarding ND, I do think a range of f stop adjustments could come in handy, depending on sunny, cloudy, extremely bright (sunny reflection off of snow), etc. So I would think a minimum of 3 ND.
Polarization may be less useful/beneficial, but could be useful in some circumstances. They certainly are designed to eliminate glare and haze, but in reality, the ones on the market are circular; meaning, you must turn the filter for the angle of polarized light you are trying to eliminate. This would be different for every direction the camera lens is pointing in relation to the source of light (position of the sun). And since you don't have the luxury of adjusting the PL for every turn the drone is making, you may not be getting the benefit of PL with every shot.
What I understand would be beneficial with PL is that you are suppose to get more color saturation. Some prefer to handle this in post, while others like to address through the lens.
I think no matter what you choose, you'll benefit, but you may find more filter choices give you greater options to chose from when you consider the different light situations you may encounter with each flight.
