Brian Fist
Flight distance : 19928 ft
Seems like SDXC cards are the most temperamental in these birds. I have found that the SanDisk Extreme series works quite well. I have used their 64GB cards formatted with exFAT without issue.
I personally have a few 128GB SDXC cards that are rated UHS-I U3 and neither of them will work in the P4P reliably. One won't even be recognized, the other will and will format, but it will do what you mentioned, just kick out of recording without even an error. It is hard to get it to happen consistently, it just happens at random times. The card that would work was borrowed from a friend so I didn't get a chance to investigate more.
One thing to try, put the Micro SD card in a PC and use the SD Formatter 4.0 utility to format it with Format Size Adjustment ON, then put it in the P4P and try recording. I have a Kingston 32gb card that would happen to and it turned out to be a bad format via the P4P.
I would be interested to know if that resolves your problem with you cards. If you could please post back it would be a great data-point to help others that might be running into the same issue. |
