Great video, I have the taco-rc filters but have not had much of a chance to test them out due to weather. Do you mind sharing the song you used in this video?
The polar pro Nd filters almost look the same as the pgytech nd filters that I recently recieved.
Every time I start up my Mavic the gimbal will get stuck slightly causing errors do the polar pro nd filters do the same?
Have no issue spending money just hate wasting money.
Quick tip if you guys are using the Polarized version. Be sure to orient it correctly. Before putting it on, look through it and rotate it until you see it cutting out the reflections, and keep it that orientation when you put it on.
A general rule of thumb, your shutter speed should always be right around double your FPS
IE: Filming 4K @ 30FPS hence 1/60 shutter speed, not etched in stone but a good place to start.
ND filters a must for bright days, sunsets & sunrises.
