Do you put the plastic stabilizer and foam padding on after use?
2705 18 2017-3-12
JBinFla
Do you put the plastic camera stabilizer and foam padding back on your drone after every use?  I'm talking about that plastic thing that holds the camera and attaches to the P4 legs, and the foam block that goes on the gimbal.  I've been doing this but notice that the most abuse the gimbal gets is probably me trying to put that stuff back on it.  Not sure if it's a good idea to keep doing it or not.  What do you do?
2017-3-12
fansa84fe8a4
Flight distance : 3 ft
Hasn't been on mine in months.  Hard case of mine has a foam cushion for the camera to rest on.
2017-3-12
Grizz 1
Flight distance : 120066 ft
I use the plastic piece for the gimbal but I don't use the foam pad.
2017-3-12
Callatis
Flight distance : 511112 ft
From my understanding the plastic piece is a must. Today I got my first DJI P4 and I am going to use the foam piece as well. It's not going to hurt.
2017-3-12
Mariuss
Flight distance : 2480515 ft
Norway
Grizz 1 Posted at 2017-3-12 13:42
Make that 2!
2017-3-12
Geebax
You can throw the pierce of foam away, the plastic gimbal lock is all you need under normal operational circumstances.
2017-3-12
RedHotPoker
Flight distance : 165105 ft
Forum friend @Rigworker, kindly gave me a nice gimbal guard/lens cap so that clear piece of OEM plastic has no use for me...
PLUS my Nanuk 945 hard side case, has a swell foam block that fits around the camera and gimbal, keeping it from any motion or jarring.
I kept that small white foam bit, in case my drone ever needs to be shipped out... I'll send it back the way it arrived. With the clear piece of plastic, at the bottom of the box, like when it was opened for the first time.
RedHotPoker
2017-3-12
Grizz 1
RedHotPoker Posted at 2017-3-12 14:37
haha  they put it in the bottom of the box in case the legs break and falls, then the foam would protect it
2017-3-12
RedHotPoker
Grizz 1 Posted at 2017-3-12 15:32
Well yes, it was sitting pretty, at the bottom of my cardboard shipping container. You have to wonder if it was just tossed in the box for good measure, or what? That was only my first disappointment...
I know, when applied correctly, it wouldn't just fall off on its own. So it was obviously never attached right, from the get go.  I've heard the same thing from numerous others here and several other RC forums as well, so I know. Mine wasn't a unique occasion.  A Common occurrence. Why?
RedHotPoker
2017-3-12
Grizz 1
I agree, when properly installed, they wont just fall off, but for everyday use I see no need for them. good to keep for further shipping purposes tho !
2017-3-12
WindSoul
Flight distance : 16 ft
i always install the plastic before boxing the drone. the foam, no, never.
2017-3-12
FCjosh
I fly a phantom 3 but I haven't used the plastic case in half a year and everything is just fine. So in my opinion it is not needed.
2017-3-12
JayOne
i use both items that came with the p4p  and the grey foam keeps your gimble into place when in travel.. so i dont think it would damage it or any form...
2017-3-12
E.T._Drone_Home
Flight distance : 99117 ft
Plastic always, foam never.
2017-3-12
Sarg
Flight distance : 330869 ft
I bought a Polar Pro gimbal guard that I use any time the P4 is not flying. I also added a "Remove Before Flying" tag in RED.
2017-3-12
djiuser_m7nWTGOcOheu
Flight distance : 79114 ft
We do, simply because I assume it is because of the ribbon cable, and perhaps other reasons that I am not aware of.  I do know that we bought a non-OEM ND lens pack and one lens came loose and ruined a 3D run as it created shots that were out of focus.  So I think locking up the camera during non-use  transport is probably a good idea, even although the vibration factor would be much less than when motors are running in flight.
2018-11-15
KEJ
Agree with you a must.
2018-11-15
1Eagle
Flight distance : 290348 ft
I have a DJI backpack and the camera and gimbal are not supported. And when you carry the backpack the drone is in a vertical position. I always use the plastic piece to keep the camera from flopping around while I'm jogging up and down mountain trails.
2018-11-15
Celipio Varea
Chile
Neither, my phantom 4 just sits for two years and more and no problem
2018-11-15
