Geebax
As Aeromirage says, the only thing you can do is set up a set of waypoints. But even though the GPS receiver in the aircraft is quite good, it may not go back to the same position with any degree of accuracy. And altitude is a barometric reading, so it could be out too. However, if your shot is sufficiently wide, and you are high enough, the image will be fairly close, and you can use image matching to overlay it more exactly. |
