plugging in a teradek bolt 300 into the Ronin blew the bolt
4045 10 2017-3-12
fans0e976150
Hello,
Today I plugged in a teradek bolt 300 in to the rear p-tap of the ronin I then powered on the Ronin and the lemo connection instantly started smoking...I have done what I thought was this setup before and I have no idea why that would have happened. I'm sure there's a good chance I did something stupid but i'd love any advice about what that was.
thanks
dan
2017-3-12
Sestaceans
Flight distance : 3963865 ft
So what was your exact setup?  What camera and were you using an aux battery??  You may have needed one.
2017-3-13
Sestaceans
Oh yah,  and sorry man,  that's a terrible feeling, really sorry to hear that.  If you give me your full setup I can try and helo you.  I run the Ronin and the MX,  both a bit differently.
2017-3-13
fans0e976150
Sestaceans Posted at 2017-3-13 01:41
Hello and thanks for the initial response...My exact setup:
-Full size Ronin with DJI Ronin intelligent Battery (purchased new from B&H
-Using a ptap splitter from the rear ptap port on the Ronin, I ran a teradek ptap to 2 pin lemo cable from the splitter to the teradek Bolt 300. There were no other devices into the ptap splitter at the time.
- I ran an HDMI cable from an A7s ii to a Small HD 502 monitor and from HDMI out, ran an HDMI cable from the monitor to the transmitter
- I powered the monitor off of LP-E6 batteries
- I powered on the camera and the monitor then the Ronin then the transmitter. The lemo connection at the Transmitter immediately started smoking. I unplugged the cable and powered everything down.
Hope this is helpful and thanks again for any advice.
best
dan
2017-3-13
Sestaceans
fans0e976150 Posted at 2017-3-13 08:35
I'll ask our engineer about this and I'll look at this tonight and see if I can find anything for you.  However from the sounds of it you may have shocked your system with two competing power sources.  One going upstream and the other downstream.. Of course I'm probably totally wrong,  but at first glance.......  Let me look at it when the unit is in front of me.
2017-3-13
fansdb0b7e6a
I had the same exact thing happen to me yesterday. I have the teradek bolt Pro 300 and plug it in to the rear Ronin MX p-tap plug and it popped and smoked. It's dead. This must be a DJI p-tap plug issue.
2017-9-27
fansdb0b7e6a
2017-9-27
DJI-Mark
Sorry to read on this. It sounds electrical although it is hard to determine why this happened. Have you considered having a technician look at your Ronin? Where are you located?
2017-9-28
Gimbal Producti
DJI-Mark Posted at 2017-9-28 06:49
I am located in Bend Oregon. If this is happening to multiple people this should be looked into by DJI. We are talking about a couple thousand dollar failure by DJI.
2017-9-28
DJI-Mark
Gimbal Producti Posted at 2017-9-28 10:21
Please contact Customer Support if you are in need of a repair. Here is the best way to do that:
UNITED STATES
DJI North America
Mon-Fri 9:00 AM - 5:00 PM (PST)
+1 (818) 235 0789
support.us@dji.com
2017-9-28
lifeon4strings
This just happened to my Bolt 300 too. Smoke pouring out from Ptap Port and Transmitter Box at lemo connection. Problem was the Power was short circuited by another device connection.(due to me plugging a Dtap Plug in the wrong polarity because of poor design on DJI's behalf allowing both directions to work) in my research into this i found that also possible is older lemo plugs being wired Pin 1 Hot and would also cause this to happen.
2018-2-12
