Donnie Stugots
Flight distance : 3636782 ft
I think that is a fair price , how may battery packs does it have ? if at least 2 and they are in good shape I would say go for it .
My rule of thumb is 60% of retail for a used Item, and it Must be in PERFECT shape.
You will love the Inspire 1 v2 . Do you happen to know how long the other owner owned it ? The reason I ask is that if you want to get say an X5 or X5 raw in the future the Inspire 1 v2 has the larger motors and would come with the X5 vibration board standard. If you are not getting the Inspire 1 V2 then I would NOT get it. ( the first run inspire 1 ( not v 2 ) will do the job but struggle with the larger cameras , also the resale would NOT be as good , In My opinion) Regarding the camera :
I normally also rotate (Yaw) the aircraft and the camera goes along for the ride , so you will get full 360 +( You would get over 360 +if in slave mode as well ) and then I use the dial for the pitch control . Just like your Phantom.
Also in the futrue being able to have a camera operator as well aas a primary is an awesome feature !
ask the current owner if it is the V ersion 2 of the Inspire 1. If he does not know ask him what vibration board came with the aircraft ( I assume he bought it new ). If it is the X3 vibration board it is the Original Inspire . If it has the X5 vibration board ( much wider when looking straight at the aircraft ) and that came with It new then it is the Inspire 1 v2. That is the one you want , it will have better value and handle the X5 cameras much better.
donnie
