DJI Assistant 2 for Linux
12Next >
24985 40 2017-3-13
Jinxos
Flight distance : 4856 ft
Switzerland
Hi there, are there plans for offering a build of the Assistant 2 software for Linux as well? The Charging Hub firmware can only be updated via the Assistant software and it would be nice if we had a way to do that either via a command line utility or the full app from Linux. Alternatively, enabling the firmware to be upgraded via the Go app would be nice as well.
Thank you in advance!
2017-3-13
Thank you for your suggestion. I will brought this to designated team for review.
Please refer to the video tutorial. You can do the update via DJI GO app.
2017-3-13
Jinxos
Switzerland
DJI Mindy Posted at 2017-3-13 22:50
https://www.youtube.com/watch?v=d47KsQhUv4o&t=86s
Thank you but the answer you gave is wrong. I'm trying to update the battery Charging Hub, not my controller/aircraft. This does not seem to be possible with the Go app yet.
2017-3-18
Jinxos Posted at 2017-3-18 03:10
Sorry for my mistake.
And there's no update for the charging hub currently.
Normally, you don't need to update it.
2017-3-18
rkwilson72
Flight distance : 892 ft
I would also like to know if there will be DJI Assistant 2 for Linux.
2018-1-25
Tukcedo
Philippines
Same here! I'm an avid Linux and DJI user and it would be awesome if we could use a native Linux app. At the moment DJI Assistant is entirely useless for me.
2018-1-27
motard
Flight distance : 1156263 ft
Portugal
Same here, no update I think.
2018-1-27
mikeseven
I have DJI Assistant 2 set up in a Windows 7 VM using VirtualBox in Linux. I haven't tried doing something like a firmware update, but what I have done seems to work ok.
2018-1-27
rkwilson72
I wonder if wine will work for DJI Assistant 2 in Linux?
2018-2-6
mikeseven
In my googling I didn't see anyone that was successful using wine. Problems with the drivers. With VirtualBox it was easy. I have valid windows licenses but I used a licensed testing virtual machine image from microsoft which made the vm install dead simple. There is the question of would I trust doing a firmware update over usb pass-thru, but I don't intend to update the firmware if I can avoid it.
2018-2-6
rkwilson72
mikeseven Posted at 2018-2-6 08:17
Wine reversed engineered Windows, so it doesn't have any code from Microsoft. I meant to try it out last night, but had to fix one of my corrupt hard drives.
Just installed wine 2.0 and one of these days, need to test DJI A2 out.
2018-2-7
rkwilson72
I just tried wine and Crossover Weaver and nothing.
I hope DJI releases the assistant for Linux.
2018-2-7
mikeseven
rkwilson72 Posted at 2018-2-7 09:29
Yes, that is a downside of VirtualBox, you need an actual copy of windows. On the other hand, since it is actually windows more programs run correctly. I wouldn't get my hopes up for a Linux version.
2018-2-7
Maxi_Mega
Flight distance : 139672 ft
I tried to launch the DJI Assistant 2 with Wine, but it doesn't work ...
So it would be nice to set a Linux version of the DJI Assistant ^^
Thanks
2018-6-26
Blue Fox
Flight distance : 296175 ft
The same for me...
Dual boot Ubuntu/Windows for the moment...
2018-12-19
Maxi_Mega
DJI Mindy Posted at 2017-3-18 23:28
Hello,
Is the designated team now working on the Linux version of the DJI Assistant 2 ?
It would be really nice ^^
Cordially,
Maxi_Mega
2019-2-14
info
Hello, same here, please release a working Linux version, there are really a lot of tech people using Linux.
2019-7-16
konanast
Greece
DJI must release a Linux or android version. It is sad that such a big company refuses to do it...
2020-2-16
jyc
Flight distance : 2255846 ft
I have been using Linux for 20 years so I too would like to have the Assistant working on my platform of choice. I just posted this to be counted that's all.
2020-2-17
HedgeTrimmer
For those wanting / waiting on a Linux version of DJI Assistant-2.  Don't hold your breath.
We are still waiting on DJI to get Windows version of Assistant-2 certified by Microsoft to where it will install without problems and bypassing system security.  The OS-X version of Assistant-2 will not install properly, leaving some parts of Assistant-2 D.O.A.
2020-2-17
TrippleDelta
Flight distance : 2228182 ft
Belgium
Same here. Not really dual boot but an external HD to boot Windows.
2020-2-17
unixstricken
Please make a linux DJI assistant application. I'm unable to update anything.
2020-6-26
djiuser_fKcIpzNlVH0z
Any updates on either progress on an official version, a getting wine working, or someone doing a firmware update via a virtual box? I'd like to be able to update firmware please...
2020-7-15
fans111ae127
rkwilson72 Posted at 2018-2-6 07:37
I have just tried running DJI Assistant 2 with Wine on Linux Mint 20.3 ulyana and it fails to load with a "serious" error
2020-7-27
elgansayer
any update?
2020-8-28
the.beard.ed
Mexico
I have it installed and can run the application using wine. The issue I have currently is that the application does not recognize when I connect any DJI gear via USB to the system. I've verified wine settings and the devices are available but for some reason, they do not trigger the program to go to the next step.
2020-9-3
Orbiter
How long would it take for DJI to compile the Assistent 2 on Linux?
2021-2-24
bjr981s
Flight distance : 139698 ft
HedgeTrimmer Posted at 2020-2-17 06:59
I have no issues with Assistant 2 install on my Macs
What is the problem with yours exactly?
Cheers
2021-2-24
bjr981s
the.beard.ed Posted at 2020-9-3 12:53
DJI Assistant sets a a USB ethernet connection to the drone.
Make sure that you appropriately set your ethernet adapter priorities correctly.
I had to tweak my connection settings for my iMac Pro.
Not sure the process for Linux with this style of USB connection but can be problematic with default routes etc.
i.e. can connect to drone but cant access web for FW files if first on the priority list.
2021-2-24
djiuser_GtWEmiYvcX8f
I know there’s no update on this issue I just wanted to add my name to the list of those requesting DJI Assistant on Ubuntu or similar. Windows 10 is bloody awful and Apple isn’t the company it once was and simply views its customers as gullible cash cows. Please do your loyal customers a favour DJI and give us a build that will work on the operating systems that more and more people are turning to. I have Windows 10 installed since Windows 7 stopped being supported by Microsoft and its bloody awful. I’d rather not have to go down the virtual box route but it looks like I’m going to have no choice at this rate.
2021-5-7
macrokernel
Russia
Need the Linux version of Assistant badly. DJI, please make a Linux build.
2021-7-20
djiuser_ejwhG36y8kpC
Please add Linux .rpm and .deb to anything you make for Windows.
2021-9-25
djiuser_eX1u8pzHQNjF
I'll just add my voice to the mix about DJI should do their Assistant 2 type application for Linux operating system (Ubuntu would be nice).
BTW people with the MAC comments... MAC OSX +  is based on BSD UNIX, not Linux.   Far as running DJI Assistant 2 with Wine on Linux, I don't know if possibly the MS .NET framework might also be needed or not, but if so the .NET is available for Linux.
2022-1-6
RSergey
Russia
I see that it is useless to ask a DJ for a Linux version package (since 2017 they have been asking and already in 2022). I went to download windows 10 and install virtual box, if it works out well, I’ll tell you (edited: yes, through virtual box it works, but takes some time to install and tune windows, usb...), if not, you need to look for good guys who have windows installed on their computer.
2022-1-22
Rob_Frohne
I am another Linux user who would like to run DJI Assistant 2 on Linux.
Rob
2022-6-22
BigJettty
Flight distance : 105358288 ft
Any news on Linux compatibility?
2023-4-21
ultraSsak
Poland
Im currently looking to purchase a drone, was thinking about dji 3 pro,
But im not purchasing anything that doesn't work with Linux.
I'm leaving this post here,  so when things change i'll get a notice.
2023-6-9
djiuser_dtajqPqOtbz4
I also vote for a Linux version of the Assistant 2 and all other DJI software,  future versions as well! Its 2023/24 you know!......... PLEASE!
I gave up windows/windoze after XP.
I think the Linux compile times would depend on the raw code file size, build and make install as well as the machine processor used.
Bob D Coder/wanna bee a bird
2023-8-14
djiuser_vNHka855VU4G
Flight distance : 1123990 ft
Sweden
Yes, Linux support for all DJI applications would be a natural assumption in 2023. More and more users are ditching Windows and Apple for good reasons. I myself have been using Linux since 1994 and ONLY Linux since XP was EOL:ed by MS. I won't even touch a PC running anything above Win7.
Offering only Windows versions of some applications (Terra and Flighthub comes to mind) in 2023 is really poor end user support, forcing users to use an inferior platform with poor security as a bonus.
2023-10-22
nsauk
Poland
I'd like to say that now in 202x you can work with USB devices from Chromium-based browsers, e.g. Google Pixel devices can be flashed using flash.android.com.
So if DJI still has doubts about whether there's a real need to maintain another OS-specific distribution, I'd suggest they can drop the Windows and Mac OS distributions instead and write a web-based tool that works on any platform where Chromium-based browsers do.
2023-11-9
12Next >
