Mavic goes into Auto-land and CAN'T cancel!!! help
2031 19 2017-3-13
fans2507b980
Flight distance : 36821 ft
Was flying about 100 ft up and descending when the mavic went into auto-land.  I was used to this happening and I expected to be able to cancel by throttling up.  No matter how I throttled up, the mavic wouldn't go up.  No matter what I did I couldn't cancel auto land.  I tried the pause button, return home, and even turned off transmitter.  Nothing helped.  It did let me maneuver horizontally so I had a safe landing, but this is really scary!  Anyone figure out what the issue is?  I could have easily lost the mavic if it landed in an unsafe place.  Battery was at 65%.
2017-3-13
Jit
Flight distance : 536768 ft
Singapore
Sounds like you have the VPS issues as discussed here (http://forum.dji.com/thread-77495-1-1.html), although it is odd that you weren't able to cancel the auto land at all. If the latest firmware didn't fix the VPS problems for you, you'd have to send it back and get it repaired under warranty.
2017-3-13
Please sync your flight records from DJI GO app and provide me with your DJI GO account email.
I'll help to review it.
Is your DJI GO account email the same as your forum email?
2017-3-13
fans2507b980
DJI Mindy Posted at 2017-3-13 22:35
yes i believe it is, i synced yesterday i think, if not, let me know and ill do again
2017-3-14
R&L Aerial
Flight distance : 298100 ft
You need to update your firmware, my mavric did the same thing and updating it to .500 fixed it. It's not supposed to go into auto land every time you pull back on the throttle
2017-3-14
CAAirborne
Flight distance : 1174232 ft
This may be the same behavior I was experiencing recently. I posted about it here: http://forum.dji.com/thread-88670-1-1.html.  For safety, there must be a method for aborting a landing after the landing sequence has been initiated.
2017-3-14
fans2507b980
CAAirborne Posted at 2017-3-14 06:54
Its somewhat similar, except mine started landing around 400 feet up and i couldnt get out of it
2017-3-14
Jason Lane
Flight distance : 260144 ft
Philippines
fans2507b980 Posted at 2017-3-14 09:46
You have two separate issues going on here...
Firstly, the Mavic going into auto-landing. As Jit suggested above, this seems like the VPS issue that many users have had. This was supposed to have been solved with the latest firmware. Was yours up-to-date? You said "I was used to this happening." Does that mean that you were aware of this defect, or have you just always thought this was normal behavior of the Mavic and not a defect?
Secondly, not being able to cancel the auto-landing. Throttling up always used to work for me. CAAirborne seems to be saying that this no longer works with the latest version of the firmware. I haven't tested this recently (as I pretty much leave Landing Protection disabled), but I will definitely test this out as soon as I can. If DJI has taken away any way to cancel an auto-landing, that sounds like a mistake to me.
2017-3-14
fans2507b980
I always assumed that if you held the throttle down for an extended period of time, it goes into auto land.  in the past, i've always been able to cancel by just throttling up for a second.  This time in particular was an anomaly.  I just updated yesterday after this incident the latest firmware, which i thought i already had, but it still prompted for an update.
2017-3-14
CAAirborne
Jason Lane Posted at 2017-3-14 10:14
Thank you for the clarification and summary, Jason.
I didn't know I could disable Landing Protection... I may try that when in a situation where a very low hover is required.
2017-3-14
fans2507b980 Posted at 2017-3-14 04:10
Could you please let me know the exact date when this occurred?
I have synced your flight records and only saw the records in February.
2017-3-14
Jason Lane
Philippines
fans2507b980 Posted at 2017-3-14 12:02
So you're not sure which version of the firmware you had at the time of the incident?
Holding the throttle down for a few seconds will initiate auto-landing if the VPS sonar detects the ground within 0.5m (1.5ft), and only when Landing Protection is enabled. Holding throttle down for any length of time at a higher altitude is not supposed to initiate auto-landing.
2017-3-14
fans2507b980
DJI Mindy Posted at 2017-3-14 20:14
yeah the sate was 3/13/17.  I'll try syncing again
2017-3-15
fans2507b980
i've synced the mavic itself, should i sync the transmitter also?
2017-3-15
fans2507b980 Posted at 2017-3-15 09:30
Sorry, it's still the same. Only the records in February.
Please follow the video tutorial to sync the flight records again.
2017-3-15
M_str
Belgium
did you try the sport mode ?
2017-3-16
fans2507b980
ok i did it right this time, i think
2017-3-16
fans2507b980
Hi Mindy, any update on this?  Thanks
2017-3-17
fans2507b980 Posted at 2017-3-17 12:43
Thank you for your cooperation.
I have checked your flight records. It's probably the ultrasonic issue.
For your flight safety, I'd suggest you to send it in for further evaluation.
2017-3-18
fans2507b980
how would i go about doing that?  Its covered under warranty?
2017-3-19
