LB2 DBUS connect two A3/N3
220 9 2017-3-13 22:33:55
bernde
Hobbyist
Austria
Hello,
I want to use Lightbridge 2 with two redundant flight controllers and a redundancy electronic.
Is it possible to connect two A3/N3 flight controllers to the DBUS Output of the Lightbridge 2 (what modifications do I need to make)?
Can someone tell me the pinout of the DBUS connector?
Pin1: +9-12V (Input voltage to LB2 receiver)
Pin2:?
Pin3:?
Pin4:GND
Are Pin2 & 3 Output Pins?
Which one is used to send the DBUS Signal?
Kind regards,
Bernd
2017-3-13 22:33:55
Seebodener
Beginner
Austria
Hello Bernd, yes it is possible
2017-3-14 07:50:17
Seebodener
Beginner
Austria
Seebodener Posted at 2017-3-14 07:50
Hello Bernd,
yes it is possible.
scroll down on this site: ViewCopter V6 Light http://www.vcopter.net/index.php/blog/blog-4
or get in contact with Rudi on FB: https://www.facebook.com/photo.p ... 9563&type=3&theater
BR from Lake Millstatt
Jörg
2017-3-14 08:04:33
bernde
Hobbyist
Austria
Hi Jörg,
I found such a cable today at Schw....hofer onlineshop, but it costs €399,-.
I think it is a little bit expensive, if it is only a Y-cable. Would be interesting, if additional electronic has been added, or if it is only a Y-cable.
Kind regards from OÖ,
Bernd
2017-3-14 10:54:18
Seebodener
Beginner
Austria
bernde Posted at 2017-3-14 10:54
Hi Jörg,
Hi Bernd,
sorry but I have no more details on the cable.
BR
Jörg
2017-3-14 23:12:02
fans9efd1eab
Hobbyist
Thailand
Its really very easy, you dont have to bye rudis "bus-splitter" he sells it very expensive and the splitter is so easy build. Everyone can make this y-cable. Please contact me and i will show you how to make it simple. Lg
2017-3-15 02:44:53
alikc218
Hobbyist
Russian Federation
Привет
Пен
+5 Tx Rx Gnd
Но A3 Получать данные из LB2 в Tx и команду передачи в LB2 к Rx , и я думаю , что только один контроллер будет работать с LB2
You can read data from LB2 using Tx and Gnd wires
Serial 256 000 bps
"0x55" "lenght of frame" "DATA" .........
2017-3-17 09:15:37
bernde
Hobbyist
Austria
alikc218 Posted at 2017-3-17 09:15
Привет
Пен
+5 Tx Rx Gnd
Hello alikc218,
can you please write in english, I don not understand russia.
Does N3/A3 send data back to LB2-RX?
2017-3-20 02:09:31
fans9efd1eab
Hobbyist
Thailand
Yes, they have to send back the telemetry data to the lb2. One channel is for rx signal and one for the tx bsck to lb. One is 9v and one gnd
2017-3-20 21:17:25
bernde
Hobbyist
Austria
Hello!
LB2 TX: Can I split the LB2 TX line into two cables, one for each Controller?
LB2 RX: Do I Need to switch the TX lines of the Controllers according which of the two Controllers is active?
Kind regards,
Bernd
2017-3-22 22:33:51
Close
DJI RecommendsPrevious /1 Next
