ProRes/CinemaDNG vs h264/h265
12254 23 2017-3-15
Flightgeist
Flight distance : 1347192 ft
Can anyone recommend a good video review of the quality differences between filming with the Pro licences and the h264/265 compressions?  Trying to decide if it is worth it to pay for the extra media and licenses -- any opinions appreciated!
2017-3-15
Cobra44Magnum
Flight distance : 935135 ft
I cannot speak to the quality differences yet since I have not shot in ProRes but I can say that shooting in ProRes will eliminate a pre-edit transcode step. On a new Mac Pro, trying to edit H.264 footage in FCPX was horrible. I didn't expect it to be that bad. Even before any transitions or text it was not realistic to edit the H.264 footage. After converting to ProRes (H.265 requires a 3rd party converter), obviously, it work like a champ. I look forward to shooting directly in ProRes and eliminating the transcode step.
2017-3-15
I 2 Fly
Flight distance : 8176 ft
South Africa
I mainly shoot in 4K H.265 (MP4) with the X5S.  I pull the footage directly into Premiere Pro 2016.  It works well but is CPU and RAM hungry - making editing and rendering slow.  The rendered and graded file is usually about 30 - 40 % of the original in size but of very good quality.  I think that one may gain some (maybe very little) image quality by going ProRes because of the compressing/codec but you will have more dynamic range and your client may demand ProRes to be delivered.   Buying the SSD is one (too expensive) thing but those license fees are ... hard to understand.  I have not paid it for using my ATOMOS Shogun also running the full ProRes!
If you are going for very good quality video in H.264 / 265 and not for the few reasons above - save your money and don't get the SSD / ProRes kit... Only my opinion...
2017-3-15
JerryLaurence
Flight distance : 21988 ft
I do wonder, if you transcoded from h,264/5 to ProRes for a client, if they would notice or care? Especially if it was for HD output...
2017-3-15
Flightgeist
I 2 Fly Posted at 2017-3-15 10:50
I 2 Fly, can you tell me what type of system / specs you are using?
2017-3-16
Flightgeist
Cobra44Magnum Posted at 2017-3-15 07:29
Thanks for the reply. Do you notice a quality difference between h264 and h265?  Also, just to confirm -- is the CineSSD necessary for prores and cinemadng but not necessary for h264?  I've noticed that the $6200 Inspire 2 Premium Combo (which comes with the X5S and pro format license) does not include a CineSSD card. Confused why they wouldn't include this if it is necessary to use the pro formats they are selling in this combo.
2017-3-16
I 2 Fly
South Africa
Flightgeist Posted at 2017-3-16 07:21
PC specs I assume?
i5, Ausus Mboard, 8Gb Ram, 1Gb AMD graphics card, Win. 7 Pro, 2X 1Tb HHDs... so really basic but working.  I'm in the process of going i7, 16Gb DDR4 Ram, Ausus Mboard, 4Gb AMD graphics card, 2X SSD 1Tb
2017-3-16
Cobra44Magnum
Flightgeist Posted at 2017-3-16 07:27
I have not done a fair, side-by-side comparison of H.264/H.265 but my perception is that the quality is better but really only noticed on larger displays at 4K. I have a 43" 4K computer monitor and a 65" 4K TV so I want to be sure that I get everything that I am paying for. I feel that the it's worth it to shoot in H.265.
Yes, you are correct, the CineSSD is only required for ProRes or CineDNG. H.264/H.265 can be recorded to a microSD card (just be sure it's a fast one for 4K video). The reason they don't include the CineSSD in general is the enormous cost. Many users won't want to pay that extra for the CineSSD. I think I see your point on the bundle, though. They are selling you something that you can't really use until you buy something else to go with it. Not sure of the reasoning on that.
2017-3-16
Barry Goyette
Flight distance : 14928 ft
We've done a fair amount of side by side testing of H264/265 and ProRes. Here are the highlights.
1. H264/h265 appear at this point to be largely identical. Even under extreme stress testing (heavy grading) we see no difference between the two. Haven't tested H265 since the firmware upgrade, so there may be some differences.
2) H264/h265 are both excellent codecs, far superior to previous DJI low bit rate codecs. The take grading very well, and many people will find them to be all that they need. The one drawback to these codecs is that they undergo quite a bit of noise reduction (smearing) and output sharpening, (aliasing) even when set at the lowest levels available in Go4 app. This is to be expected, but is the primary difference you will see in comparison to ProRes. Some people prefer the over sharpened look of the h264/5, but as a professional, ProRes gives you the ability to sharpen in a more granular way in post, giving you slightly more delicate detail, and a minimum of sharpening artifacts.
3) ProRes will have slightly more noise, but it is generally fine and reminiscent of film grain. It handles highlights better in D-Log than H264 (which currently has a slight error in the encoding of d-log), and in theory will accept more adjustment in post than the H264/5. (So far I'm pretty impressed with how well the H codecs grade, but proRes should, again in theory be even better -- in my tests so far, I really haven't seen the H264 codec "break" or band with extreme grades, in the new firmware, so it's hard to absolutely say that ProRes excels here, except in theory).  Currently ProRes is limited to D-Log and standard profiles, and doesn't have M4/3 lens corrections applied, which is problematic on the wider lenses including DJI's stock lens, so it could be considered limited for now.
4) RAW is really not a video codec and so it's main highlight is it's ability to be handled like a RAW photo in photoshop, This results in the post process being much more time consuming and also much more controllable. Image quality in Raw is not necessarily better than proRes, but you can apply much more extreme adjustments to the imagery. There is currently a lens correction error with RAW involving the 25mm lens, that leads to uncorrectable Chromatic Aberrations. This will hopefully be corrected (by Adobe) soon.
2017-3-16
thomasakira
Flight distance : 921693 ft
this is the difference, dng you can manipulate a lot more in post....h264 aside from the compression issues will generally yield something very close to what you shot
2017-3-16
Barry Goyette
thomasakira Posted at 2017-3-16 13:33
While what Thomas has said about raw is true, you do have more flexibility with RAW, this h264 codec does seem to take rather significant grades with ease. Here's an example of the new D-log shot in H264. The older version of this shot would have been a mess, with ruddy messy shadows and highly compressed highlights. This shot was exposed about as far to the right as possible, and then pulled back down, to see if I could expose any banding in the sky.  And there is some...but its not horrible (made worse by the compression required to attach here on the forum), and certainly, had I chosen a more normal exposure I could have minimized that to some extent.
2017-3-16
thomasakira
Barry Goyette Posted at 2017-3-16 17:00
this is impressive for h264
2017-3-17
Flightgeist
Thanks, excellent post and very helpful.  Are you touching the sharpness settings at all in h264? Anything else to know about the way you shot it?
Lastly, have you done any tests on h264 vs h265?
2017-3-17
Barry Goyette
Flightgeist Posted at 2017-3-17 15:00
I turn the sharpness settings all the way down on H264, and frankly, all the way down isn't really enough. Part of the secret sauce of DJI compression is some pretty strong noise reduction followed by some pretty strong sharpening. The noise reduction eliminates noise and some detail, which helps in compression, and the sharpening gives the "impression" of more detail, although it is false detail, and is problematic on a lot of levels.  The reality is, DJI has to make a compromise to get this much resolution down to 100mbits, although I'd prefer if they allowed you to turn off the sharpening completely, because there are better ways in post to crisp things up than what they can do in camera. I think the vast majority of their customers love the extra sharpness (and often complain that the ProRes looks soft, even though it has slightly more actual detail), so I doubt we'll see much change in that.
I have previously tested H264/65 and see zero meaningful difference between the two under pretty strong stress testing. There are some small differences about how the color sampling is encoded, but you'd have to really destroy the footage to see the difference. If you are on  windows and can get H265 going, then there's no reason why not..but on a mac...I don't think all the extra transcoding work is worth a bleep of difference in the final output.
2017-3-19
Maxwhiteuv
You can have a reference at this article:
http://www.newsshooter.com/2017/06/13/why-shoot-raw/
2017-10-31
rmaxwell.dccnet
Flight distance : 698661 ft
I have been following this thread and I think that the original question requesting a review and comparison of the quality of H.264/H265 with ProRes and CinemaDNG is not the right question to ask.
H.264/H.265 has the following characteristics:
1.        The compression used has run-length encoding.  The full data of a single frame is not present.  It has key frames and difference frames.  You have to transcode it to get all the frames back.  You always loose some quality when you transcode.  Professional editing requires full data for each frame.
2.        It uses fewer bits per color, which means you select the dynamic range when you shoot.
3.        You do not have the full 14 stops of dynamic range that ProRes and CinemaDNG offer.
4.         You do not have the choice of using D-Log curve or D-Gamut RGB color space.
5.        You do not have the maximum flexibility for professional color grading and post production.
6.        Sometimes you are unable to get your footage to match other cameras used on a production.
If you are only delivering video for amateur or web productions, use H.264/H.265.  However, if you are expecting to produce professional broadcast or professional movie productions, you will need to do professional post production which requires ProRes and/or CinemaDNG RAW data out of your camera.
It all boils down to having more flexibility in post production.
2017-11-4
DRAGenDROP
Flight distance : 26170253 ft
Stay at 265.
Your clients will not pay more for proress.
H265 is great and good
2019-1-29
DRAGenDROP
On the new MacBook Pro the H265 works perfect in realtime
2019-1-29
RikDingo
Flight distance : 2358225 ft
I have a proRES licence with SSD 240 Go.
Not a  scientist test, just a feeling... At the end of the day, if you have made the right balance, ISO, aperture, shutterspeed it is not easy to see the difference between h264 / h265 and proRES.
BUT there is one thing that is clear : editing proRES is MUCH MORE easy for my computer when I use premiere.
So, YES the price of licence+SSD is really too high, BUT the time saved compensates.
2019-3-3
RikDingo
This is H264
This is proRES
2019-3-3
Orrus
Flight distance : 213783 ft
@RikDingo   Is that footage from the X5S or X7S?        And which lens were you using for each video?
Great videos btw!
I'm really struggling to get any sharp video out of my Inspire 2 with X5S and DJI 15mm lens.
I certainly can't get anywhere near the clarity of these videos.
Anyone have any ideas what might be causing the problem?
2019-5-29
Matthew Dobrski
Flight distance : 1831050 ft
Orrus Posted at 5-29 06:57
Great videos btw!
Not without examining the samples of original footage from SD card. Download several short samples to Dropbox ...
2019-5-29
RikDingo
Great videos btw!
X5S with lens 12mm
2019-5-29
Orrus
Matthew Dobrski Posted at 5-29 11:06
I've started another thread about my issue.
https://forum.dji.com/forum.php? ... D560%26typeid%3D560
Theres a couple of drop box links to some of my footage.
2019-5-30
