Ronin MX Vibration issues
2652 2 2017-3-15
FilippoM
Hi everybody,
I bought a Ronin MX in October and it worked fine until now that I am getting some vibrations issues.I have always been balancing it properly, and it always worked perfectly, but suddenly now I get those vibrations:
Has anybody experienced the same problem?
Thank you very much!
2017-3-15
3x3q
Flight distance : 815666 ft
Make sure EVERYTHING is tightened down properly. Most of the time when I experience vibrations like this, it's because I forgot to tighten something.
If it persists and you're positive that you've balanced/tightened perfectly, increase the outfilter value on affected axes. It "filters out" high frequency vibrations. Start with low values, and increase until there isn't any vibration.
2017-3-16
Kover
Belgium
3x3q Posted at 2017-3-16 10:15
Hi,
Having the same problems now. Already set the stiffness to the maximum possible.
Could you be more specific on how much you increased the outfilter value please? 10, 20 , 30,...?
Thanks in advance
2017-5-17
